I would like to remove the back cover from the Samsung 2032MW
Bought this unit some tiime ago and now want to wallmount the unit. SInce no screw mounting, thinking of opening the cover and reverse mount ie instead of the screw going from bracket into LCD cover, I dril the holes and thread the screw from inside the cover out to the bracket.
robotek
  • 1512 Answers
SOURCE: I cannot remove the fan
Hi Skyy, it may just be stuck against a rubber sealing gasket. Have you tried gently levering it from one corner to break out the adhesion of the gasket/
regards
Graeme
Posted on Mar 22, 2008
jerryg50
  • 1689 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
JOHNSONELECT
  • 113 Answers
SOURCE: There are no bolts to mount my Samsung Series 6 to my TV Stand
YES TAKE THE SMALL BOLTS WITH YOU AND GET LONGER ONES
Posted on Aug 24, 2009
What wallmount for 48in 4k smart tv
there are a number of wall mounts for tv units so talk with a salesman in a tv shop and get one that is suitable for you and the tv
if you don't have the screws , then see if he has then as well as they are a set size and length for the back of the tv
May 07, 2016 | Televison & Video
Tip
How to Replace the Ballast in a Samsung DLP
Fist what is a TV ballast?
A television's ballast is a device connected to the lamp that provides an electric current, keeping the lamp operational. If you have a new lamp that isn't working properly, then you will more than likely need to replace the ballast. Replacing your television's ballast is less challenging than working with other parts of a Samsung Television, and is something that you should be able to do yourself.
  1. Remove the back panel of your Samsung DLP television, and then remove the lamp.
  2. Carefully unscrew the cover sensor switch, which should be located near the bottom-right side.
  3. Remove the two screws holding the lamp connector in place and slide it out.
  4. Remove the screws holding the inside unit of the TV in place, and very carefully ease the right side out, allowing access to the ballast.
  5. Unscrew the circuit board, remove the two cables going to the existing ballast and replace it with the new ballast in the same fashion.
  6. Put the inside unit of the television back in place and screw it in.
  7. Reattach the cover sensor switch.
  8. Reinstall the lamp and screw the back panel of the television back into position.
hope it works..
this is a image of the ballast of a Samsung .
on Mar 25, 2010 | Televison & Video
Samsung tv pixel problems
if nothing has happen you tv just change the cables and see if not work send your tv to manufacture or retailer if there is a warranty hope that it will help you
Feb 15, 2014 | Samsung Computers & Internet
I have KRX 891 Kenwood Stereo system... The receiver just stopped working one day about 4 years ago... i found out that Radio Shack sells fuses, and i have asked in the past if it could be a fuse, but...
Karen, this may be an easy fix. There are a couple of screws on top of the unit and about 8 or 9 around the back edge. First make sure the unit is unplugged. Remove these screws andyou can lift the cover off. On the left side you will see 2 glass fuses. Gently pry these out and you will see they are marked on the end caps with voltage and amperage ratings. Replacements are very affordable at Radio shack. Good luck! B-) wayne2ears@gmail.com
Nov 24, 2013 | Audio Players & Recorders
Tv wont turn on'
it's a capacitor issue-Samsung will cover a one tiime repair of problem call 1-800-samsung
Aug 09, 2010 | Samsung LN32A330 32 in. LCD TV
Stripped Screws
try to remove it softly by using small blade or pin
May 10, 2010 | Palm Tungsten E2 Handheld
I cannot remove the stand for my evotel elcd32usb, can you help me please
There are 6 screws in the centre back of the TV, 2 rows of three. There are arrows embossed on the plastic case to identify them.
Remove all 6, then pull the stand off.
Apr 26, 2010 | Televison & Video
I can't remove the thermostat from the wallmount, it seems to be stuck together
Hi, the thermostat is in 3 sections. First you will have just the plastic cover that just snaps in place. Then comes the stat. You will have several slot head screws in different areas of the stat to loosen up. You will need a small tip slotted driver as they screws are small. They will not come out, just loosen up. You will know when you have found all of the screws as the thermostat will become loose and you will be able to remove it. The last part is the sub-base. It will have the control wiring connected to it, and is normally held to the wall by a screw and anchor at each end. So, just remember that all stats have 3 sections, cover, thermostat, and last, the main sub-base.
Apr 10, 2010 | Honeywell Programmable Thermostat Heater
Small plastic toy down lint trap
is the lint filter on the top of unit??? if so you ll need to disconnect power remove the 2 phillips head screws under the lint trap holding it to the main lid. then after removing about 10 1/4in screws from back panel you ll see a metal sleeve running down the back of the unit( the lint filter actually slides in to it) ending in a circular shape below. remove perhaps 4 more screws holding that panel on and youll gain acess to retrive whatever has fallen down there. easy enough to do yourdself no need to call in a professional
Oct 23, 2008 | Dryers
Acer AL1916W 19" for wallmounting
remove the both screws at the backside and stand will go unmounted.. now you need two stripes to hang your monitor on the wall.
Jan 24, 2008 | Acer AL1916W 19" LCD Monitor
Televison & Video Logo
362 people viewed this question
Top Televison & Video Experts
