Question about JVC Everio GZ-MC100 Memory Card Camcorder
Cannot film movies/take pics, but can record sound (corrupted folders?)
My camera (GZ-MC100) stopped partially working. I was able to take pictures and view them but not film/view movies. When I tried to film st. it said st. like video management was corrupted. When I tried to restore it hanged up and the green light started flashing on the camera. I pulled out the batery, but same problem repeated many times. I run a chkdsk on disk and it found some corrupted files, so I said it to fix it, but it changed DCIM folder to a file. Now I am not able to take picture nor film anything. I can see in view mode, that there isn't any movie, but can see boxes for pictures. However when I switch to camera mode, there aren't even boxes for the pictures which looks st. was deleted on the disk (also say No image files). If I switch to a mode where I should take a pictures/film movie, there is sign "please wait" ,the raining effect appears on the display and the green lights start flashing (1 together with 3rd and 2nd). I tried to hold Mode & Menu buttons for 5 secs. but doesn't reset anything, and all 3 lights will start flashing after a while. However still can record/playback sound. Now the structure of the folder is as follow: .Trashes DCIM (empty) DCVC (empty) |--101JVCMC (empty) EXTMOV FOUND.000 SD_VIDEO |--MGRINFO--| | |--MGR_DATA | |--PRG_MGR |--PRG001--| | |--PRG001.PGI .DS_Store .DS_Store Any advice strongly appreciated.
SOURCE: Broken video management file/ recording failure
Although the instructions don’t make it clear, it seems to be important that the camera is turned off before you connect or disconnect the USB cable. The instructions do mention that you should not delete or rename files on the camera except in the EXT_MOV folder. The camera’s firmware is apparently quite fragile about file names and the presence of the extra hidden folders that both the Windows and Macintosh operating systems create when you delete something.
Posted on May 21, 2008
SOURCE: P0WERCINEMA NE FOR EVERIO
I had the same problem & just installed windows vista updates for Intel corporation which was an optional update, it has finally fixed my problem with the green lines!
Posted on May 26, 2008
SOURCE: screen says video management file is broken
Gary - not an answer - but mine just started doing the same thing. It was working perfectly fine and one day I turned it on and this message pops up. I've tried everything to reset or "fix" the problem, but it just keeps giving me the same message. This is happening in the video mode and when I press the button to review videos. I'm getting on the phone with JVC today to try and figure this out...hopefully it won't result in having to send the camera anywhere. I'll report back if I get any useable advice.
Chase
Posted on Jun 06, 2008
  • 3 Answers
SOURCE: Video Playback on a Everio GZ-MG57U
Sounds like you just need to upgrade your codecs. I use media player classic or VLC media player so I've never had these "not" play. Also another thing you will run into is the widescreen not showing properly when it does work. You have to convert the video to proper divx format with Xillisoft video converter in order for it to appear in 16:9 in all players. Makes the files 1/10 of the size too with little quality loss. Make sure you get the newest divx and xvid codecs, or a media player codec pack (easily found in google).
Posted on May 14, 2009
I just read on a review site that this camera shuts down in loud situations. I tried to use it mounted to my harley and am getting that error as well,I'm going to try turning off the mike(since the sound will have to be redubbeb anyway. I'll let you know..
Posted on Sep 06, 2010
Lost disk, new computer, how do I download from my JVC GZ-MG130U?
Have you tried the cord from your camera to your computer's usb port? It should be recognized by the computer, allowing you to transfer your videos to a folder. The camera has a built in memory, so you have to use a cord to transfer the movies and pics.
Mar 30, 2010 | JVC Everio GZ-MG130 Camcorder
Hi there, Im having problems with my camcorder model GZ-MG20EK I can record sound, but not picture on both film and Camera modes. The monitor works fine and I can access menus......please help !
If you have background doing these things, go open your camera up-to where you can move the OP block out(LENS ASSY), remove the iris unit from the assy and then take out the curtain(shutter) and clean with video clean or any alcohol base cleaner. Take extra care with flexible wires. Let it dry and then re-assemble and your done. Good Luck
Mar 13, 2010 | JVC Everio GZ-MG20 Camcorder
Software to edit MPEG2 format film
try the software that came with the camera if not then go to Everio and see if they hae some patches to download good luck
Sep 21, 2009 | JVC Everio GZ-MG360 HDD Camcorder
What kind of card is best
The MPEG2 recording can be used in various quality levels, with 8.5 to 5.5 Mbps constant bit rate and 4.2 and 1.5 MBit / s with a variable bit rate recording.
The read / write speed is 20480 kb/s (SanDisk data).
It's enough!
Calculate the recording time: click
Jun 06, 2009 | JVC Everio GZ-MC100 Memory Card Camcorder
Jvc gz-mc100 not powering up
I had the same problem. I think the fault happened when i've charged 2 compatible batteries one after another. warmed up to much i believe. Had to send it for repair. cost me 100 euros
though luck...
Dec 06, 2008 | JVC Everio GZ-MC100 Memory Card Camcorder
JVC Everio GZ-MG330 Camcorder converting
Here you go:
1. Connect you usb to you computer and camcorder
2. Camcorder ask do you want to playback, backup, create dvd, direct print.... Choose playback
3. Option pops up on your computer.. Select "Take No Action"
4. Go into My Computer and open the E: or Everio_HDD
5. >>For movies- Select SD-Video - Folder PRG002 or PRG001 are where your movie files is located
Drag and drop .MOD files to your desktop **.MOI files are indexes of the .MOD files and will not convert **
>>For Pictures- Select DCIM - Folder 101JVCSO or 100JVCSO - Drag and Drop to desktop - NO FILE CONVERSION NECESSARY
6. Change the file extension to .MPG
** If you find yourself having issues changing the file extension, open my computer... select tools... go to folder options.... un-check "Hide extension for known file types", check it back when your finished if you have kids.. I do for my computer.***
**You are simply creating copies of your files when you drag and drop you movies and pics***
These step will allow you to view back you movies using Windows Media Player until you get your software.
a986525.jpgDon't forget to rate!!
Dec 01, 2008 | JVC Everio GZ-MG30 Camcorder
Download manual for JVC Digital media camera GZ-MC100
If you are looking for User Manual of GZ-MC100, you can download it from JVC Support.
Nov 29, 2008 | JVC Everio GZ-MC100 Memory Card Camcorder
Download cd's for jvc gz-mc100
this camera doesn't come with software to transfer videos. Just plug your camera (or insert the cf card, on a card reader) and copy your videos to your pc. you can use the image import feature on windows to do the job (but don't delete the videos with your pc. If you do the camera will state a error)
hope it helps
marco
Sep 26, 2008 | JVC Everio GZ-MC100 Memory Card Camcorder
Free Software Download from Net
My camera ( Sony Cyber Shot W 30's memory stick is not working and i am unable to dowload pictures from my camera on to my laptop. My laptop's OS is Windows Vista.
Please let me know how could I go about downloading pictures from my camera to my laptop.
Many Thanks.
Prachi Vashisht.
prachivashisht@rediffmail.com
May 17, 2008 | Kodak EasyShare C653 Digital Camera
JVC Everio GZ-MC100 Memory Card Camcorder Logo
56 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
