Question about Whirlpool Calypso GVW9959K Top Load Washer
MY WHIRLPOOL WASHER FLOODS YHE FLOOR ON FILLING BEFORE IT START T
THE TUB CONTINUE TO FILL AND WILLNOT START TO WASH CYCLE
    Sergeant:
    Champion:
  • 291 Answers
You have a bad pressure switch or the hose come off in a unbalanced wash ,,, look in the top and check the hose (about a 1/4 clear hose) and make sure its still connected to the valve and if so replace the valve.
Larry
Posted on Nov 25, 2008
KENMORE DISHWASHER, WATER CONTINUES TO FILL AFTER WASHER IS SHUT OFF.
You're correct you have a faulty water inlet valve. At the end of the wash cycle the solenoid in the valve is not closing properly to not allow water to re-enter the tub. For further assistance with this repai
Jan 21, 2014 | Computers & Internet
My Whirlpool washer tub filled with water, did not spin, over flowed, and partially flooded my floor. The final spin cycle did remove the water out through the hose. How can it be fixed?
the pressure fill switch has become disengaged....remove screws holding control panel and raise it up,you will see a plastic tube has become disconnected and must be reattached to a component directly under load size selector switch,usually a rust or orangeish color,sometimes white
Mar 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Random filling of the tub, door open, leaks on floor.
The only thing that can admit water with the power off to the machine is a bad Fill valve. Replace
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Tub will not start the wash cycle when filling, and will not stop filling
Hi, sounds like you wil need to change the inlet mixer valve. Did it continue to fill with the washer turned off? Let me know so I can assist you further.
Thanks
Vic
May 16, 2009 | Washing Machines
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
Water leaking on the floor while filling
Open the back of the washer. Start the fill cycle and observe where the water is leaking from. You are not going to get a full view of the entire tub by only opening the lower front access.
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When starting the washer, it occasionally will not fill
Check the drain hose. The open end of the pipe the hose drains into must be higher than the top of the washer's tub (usually 30 inches or so off the floor, minimum) or the water can siphon right out. The drain hose should not be a sealed connection to the drain pipe. Try to extend the drain pipe up to about 36 inches off the floor level.
Jan 10, 2009 | Whirlpool Washing Machines
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
Dec 03, 2017 | Whirlpool Washing Machines
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Calypso GVW9959K Top Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal De
