Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper jam problem in pixma mp145. E3 error.
I have a problem in canon pixma mp145. it is showing paper jam problem. and E3 error.
  • 9 more comments
  • shaikhsam
    shaikhsam Jan 22, 2009
    i buy canon PIXMA M145 one month before , it work good till this morning , but sudeenlly JAm paper . i had removed that paper without tear, now it always feed paper one side and getting jam , there is no any foreign bodies insidfe the printer. i tried lot but failure all time to resolved my problen . i tried contact for canon assistance but not satisfied , plz tell me how to getting rid of this issue if anybody knows.
    sameer.
  • wan gjentayu wan Feb 11, 2009
    alarm problem e3..tell me how to repair
    -wan
  • Anonymous Mar 23, 2009
    I have the same error where the paper feed at the right side and there there were nothing got stuck in btw of the roller...
  • redman12 Apr 17, 2009
    fixed problem but problem occured again
  • marquis_djar Apr 22, 2009
    i tried your solution joe but it doesnt work. the alarm LED just blink 3 times and that's it. i dont know what to do..
    can someone help me..!?
  • Anonymous Apr 28, 2009
    paper jam problem in pixma mp145. E3 error
  • pajnal May 11, 2010
  • ece suryadi Oct 21, 2012
    printer posisi on dan yang muncul angka 2, 4 lampu kedap kedip gimana solusinya
  • michael panther Mar 04, 2013
    can anyone please tell me how to fix the Error code 23 in canon pixma mp145. Thanks in advance.
  • YaoYY
    YaoYY Nov 13, 2013
    Here the 3 step simple solution (1) Turn off your printer (2) Put one plain nice A4 paper at entrance of the back roller.(3) Turn ON your printer *The printer will start moving your cartridge and also all the roller. The plain paper you put in then will be rolled out. If anything stuck at the roller, the plain paper will clean it out for you. After that your printer will be OK and the LED panel will show "1"
  • Anonymous Mar 28, 2014
    i just purchased a new canon Pixma mx452 i need to learn how to fax a paper what is the first step
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Posted on Nov 29, 2008
  • Canon Master
  • 4,338 Answers
Perform the steps to reset the EEprom:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
  • Haidee88 Nov 24, 2010
    Can you help me with error e3? it says it has paper jam but there is no paper inside the printer. what should I do? Thank you!
  • tanactanac May 01, 2011
    This is a waste of time.
How to fix error e3.i am not being able to reset my canon mp145.the paper is getting jammed.
Posted on Apr 11, 2010
  • 4 Answers
Change your Feeder to solve the problem in mp 145
Posted on Jul 10, 2010
Posted on Oct 01, 2010
  • Chinmaysarka Oct 01, 2010
    Open the printer cover and check the left side wheel black belt whether it is loss or not if loss than tighten the motor with which the belt attached cause some time the motor come front by printing pressure for what the hole wheels assembly can’t lode the paper for which much strength needed.
Erm...i also encountered this type of problem b4...what i do is i put the paper inside so that it could be rolled when the printer turn...then when the printer start rolling the paper, i hold the paper half so that it can't move out until the roller stop...then the led start blinking and ask for removing the jammed paper...so i pull out the paper from the printer manual and press color button...then the printer will be back to normal...method that i done was make the paper really jammed even though it was not jammed
Posted on Jun 13, 2010
back roller.
If anything stuck at the roller, the plain paper will cleanit out for you.
Posted on Aug 03, 2012
  • YaoYY
    YaoYY Nov 13, 2013
    Yes, this really help. Thanks!
  • 25 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
541
Posted on Feb 27, 2009
Try this one...dissect the printer be sure you know how to put it back. their is a spring near the waste pads. I think it is a part of the gear assembly. These spring with gear sometimes loose. you will have to put it back, (note: if the spring is still aligned) if not....change the spring with the gear. Hope this one will help someone......AGB_ZHEED
Posted on Jun 15, 2009
3 Suggested Answers
  • 14 Answers
SOURCE: paper jam problem in pixma mp145. E3 error.
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
  • 63 Answers
SOURCE: paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Posted on Feb 03, 2010
Paper jam (e3) BUT no paper jam
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Describe your Canon PIXMA MP160 All-i have a
hi,
pow-e-r-18
Jun 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer Error E3
E3 error -
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [Black] or [Color].
The above is direct from the user manual.
If there is no paper jam - look for any small pieces of paper that could be located near the roller sensor.
Oct 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp145 error 3
it means that there is something still trapped inside. a piece of paper maybe or anything. are you sure you already remove the whole piece of the paper or not?
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
E3 Error
Aug 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
25,399 people viewed this question
old marine
old marine
