Question about Kenmore 72602 Gas Dryer
An Old Gas Kenmore 7870701
My dryer makes a buzzing sound when pressing the start button, but it won't turn. Please kindly advise. rgrds, Michael
My Natural Gas Kenmore Dryer was working OK until the company change the meter, they put a new one but my dryer 90 series does not work, the light go on, I tried all de programs, It go to the driying but kepp orange , should be green, could it be air on the pipe? Thak you
Posted on May 25, 2007
    President:
  • 878 Answers
Michael, here are a few things to check. Can you turn the drum by hand? If not you may have something in the blower wheel binding the motor. You can acess the blower by removing the back panel and removing the two screws under the vent screen on top. Once the back panel is removed the blower wheel will be behind the vent. Three or four screws and it's off. If the blower wheel is ok, it may be the motor itself going bad. Have someone hold the door switch down and while pressing start, give the drum a turn. If it starts running, it's probably a bad motor. Other things to look for is bad rollers. If they are bound up it may prevent the dryer from starting. Check these things out first...Catriver..post back.
Posted on Jan 04, 2007
SOURCE:
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Kenmore gas dryer model 84152 wont start
-Make sure turn select knob to correct position.
-try again.
Good luck
Mai
Dec 16, 2013 | Kenmore 800 7982 Dryer
My kenmore dryer push start button is not holding...it engages the unit but the button will not stay on! Any advise
if the start button is making a buzz sound and not kicking the dryer motor in then the motor is bad-mike
Mar 01, 2010 | Kenmore Dryers
My kenmore dryer makes a buzzing noise when I push the on button and will not turn on.
When you press the push to start switch and you hear a buzzing/humming sound, it is the motor that has gone bad and CANNOT come on. PLEASE check the motor to see that IN FACT it is bad and that there is NOT SOMETHING foreign somwhere in the blower wheel or elsewhere stopping the system from freely turning
Nov 20, 2009 | Kenmore Dryers
Gas dryer wont run
Hi. there can be many issue that can cause this type of interruption in normal operations. Lets go threw a few.One could be a faulty or dead motor. The timer board sends a signal to the motor once the start button is pushed. If the motor is malfunctioning or the wires that connect to the motor are lose or old and worn, the motor will usually click or buzz. the fault itself can be within the timer assembly or the motor itself. the best way to find out is to test the current flow at the motor by using a multimeter. connect this meter to the motor terminals and select the cycle and hit the start button. if the meter reads voltage at the motor and the motor clicks or buzzes, this will confirm an actual motor failure. if the voltage at the motor is weak or not there 0, this means the timer will need to be replaced. Next, I would check the door switch for its operational value. you can use the same method as i discussed above with the meter. use the terminals for testing on the switch. This could be a problem area as well. if the switch is malfunctioning, the dryer will not run at all. you will find the problem in one or both of the discussed areas above.
please rate and god bless.
Mar 25, 2009 | Kenmore Dryers
Gas dryer drum does not spin
defective motor,,replace,,,onthejob
Jan 11, 2009 | Dryers
Dryer will not start
Hello jslovik,
Welcome
You said, When you turn the knob a buzzing sound starts but that's it. The Buzzing continues as long as the start button is turned. Dryer is only 2 years old. Any help is very appreciated.
It sounds like the starting switch is bad!
10 134398300 Switch,start ,turn type In-Stock $ 11.29It appears in the diagram at the page below in diagram # 10
http://www.pcappliancerepair.com/model-display.php
If you do not know to diagnose this or repair it, please call an authorized tech.
Let me know what you do and how it goes for you?
Huuum
Believed I solved your question.Happy to have been of assistance.
Please remember to leave a rating.
Sep 19, 2008 | Frigidaire FGQ332ES Gas Dryer
Kenmore Dryer
The start button works like a push-on switch that engages the timer switch. It's all one unit. It isn't engaging because the internal lever the engages the switch is either broken or worn out. The start timer/switch will need to be replaced.
Jul 09, 2007 | Fisher and Paykel DG05 Gas Dryer
Kenmore 72602 Gas Dryer Logo
121 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
