Question about Sony DSR-45 Mini DV VCR
Can't control DSR-45AP using Avid Medialogger
I'm having problems controlling my DSR-45AP deck using Avid Medialogger. I'm trying to control it using RS-232 as its plugged straight into the PC com port.
I've set it to RS-232 mode and set it to remote yet the AVID Media Logger software can't find it. I can control other decks such as J3's using the Media Logger using software so the problem is with the deck.
I will point out that I only have a deck template for a dsr-45 deck within the logging software. Is there a particular setting I can configure within AVID?
thanks
Beren
Shuttle83
  • 1139 Answers
SOURCE: DSR-11 not recognized by FCP
Hello tommy_bee, Try the advice offered on this link. http://forums.creativecow.net/readpost/35/856108 It has helped me
Posted on Sep 11, 2007
SOURCE: Sony DSR-45 Lost Firewire Signal
Port's fried for sure -- that's a classic Firewire Port Burnout problem. Could be a cheap repair if you can take it to someone who's not afraid to get their hands dirty (soldering, perhaps). I don't know how integrated the port is to the unit (like on a laptop) so good luck!
Posted on Sep 20, 2007
Shuttle83
  • 1139 Answers
SOURCE: Motor boat sound
This is caused by a grounding issue, an audio oscillation is being feed back through the ground. This is an indication that one of your units is not properly grounded or improperly isolated. Check your grounds and make sure everything is grounded if your system is a common ground system. If the system is an isolated system, make sure everything is properly isolated. the problem is your system is somewhere in between these two states and that is what is causing this problem.
Posted on Jul 17, 2008
SOURCE: My deck currently will not log and capture footage into my Final Cut Pro.
The problem is that you have a son of a biscuit.
Posted on Sep 23, 2008
  • 454 Answers
SOURCE: I NEED A SERVICE MANUAL OF DSR-45AP,HOW?
Lots of online sites have user and repair manuals. Here's one:
http://s100-manuals.com/search.asp
Do a web search for Sony DSR-45 service manual, you will find lots with a little looking. Most will charge a small fee aor service manuals. Also check eBay.
Posted on Feb 06, 2010
Error codes c 31 70 of sony dsr 45ap
U can do one thing check the switch at the front of DSR is in remote or not. If it is not then.Then press the reset switch is just below the the LCD. or Press eject button with pressing power supply .
Jun 27, 2013 | Sony DSR-45 Mini DV VCR
TELL ME ABOUT ERROR 3270 FOR DSR-45AP
it is error in a Eprom IC.in VD board
Jan 04, 2011 | Sony DSR-45P DV / Mini DV VCR
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
Try to playback with other tape recorded earlier from other camera or VTR .If other tapes are palying properly without any glitches then it might be the problem with this recording.
anand
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
Feb 06, 2010 | Sony DSR-45 Mini DV VCR
91-215 error code
91-215 is "communication error between system control and keyboard." could be a loose cable, open fuse, capacitor problem, etc.
Mar 20, 2009 | Sony DSR-1500 Mini DV VCR
DSR-11 stopped outputting anything
I have almost the same problem!  Did you ever figure out what happened?  Here's what I had posted yesterday:
Tech Friends -
I recently got a non-sony tape stuck in my DSR-11 (bummer) and was forced to extricate it using the "my tape got stuck in the DSR - 11" article's method of removing the top cover and highest level of circuit board:
http://www.fixya.com/support/t178954-tape_stuck_inside
This worked for the tape removal, however, upon replacing the circuit board and cover, the deck no longer seems to be able to do anything with video or audio.  It still communicates with FCP via its firewire connection (ie FCP is able to control FF, rewind, play functions, etc), but it seems unable to read or write video.  Also, we use it as an A - D converter box between a Beta SP deck and thecomputer (actually, this is the deck's main function here).  Even when I switch it to the correct setting (video) and check to make sure that everything is plugged in correctly (trust me, I checked, it is), I get the "there is no video here" error message.
Also, after trouble shooting the drive for a little while, I pressed the "reset" button the the rear.  I'm not sure if that matters one way or the other.  I don't think it does (that just resets the time code, right?)
The question is, would this be a case of "fried firewire jack" such as it seems so many of us DSR - 11 owners have?  Could I have done any frying myself by not having myself properly grounded when opening the shell?  Is there anyone who knows the answer?  Help!  I can't digitize my video!
Comment by eltriunfo, posted on Sep 05, 2008 The Plot Thickens...
Okay, I've checked all of the FCP settings and played with the deck more and it's only confused me more.  I can now get it to not only be controlled by the computer, but actually print audio and video to mini dv tape.  Also, I can record from my Beta SP deck to miniDV tape in the deck (connected through the "video" input on the rear of the unit).  In other words, the deck seems to function perfectly doing everything except for converting analogue to digital passively.  The way we always did it before was by keeping the input switch on the face of the unit on "video" and log and capturing in FCP with it as a noncontrolable ntsc device.  This makes me understand it less.  It means to me that it is not a broken switch, it's not a broken firewire port, everything works perfectly EXCEPT for using the unit as an A-D converter.  What the dill-yo?  If anyone in the world could offer any insight as to what could be causing this I would greatly appreciate it!
Jun 19, 2008 | Sony DSR-11 DV / Mini DV VCR
How do I record just VO on the AVID? I can't find the tool to disable deck control for VO record only
In the Capture tool the Icon that looks like a deck. If you click that till it has a circle with a redline through it that disable deck control for recording VO.
Feb 19, 2008 | Avid Xpress Pro - (bundle) (05600360101)...
Avid Xpress Pro - AVID crashes when deck is turned on
This sounds like a fatal error out side of avid settings, you're going to need to do an avid reinstall to replace any currupted files. Just back up your media capture and .bin / avb files. Does xpress let you create an omfi file just import that rather than relinking?
Nov 27, 2007 | Avid Xpress Pro - (bundle) (05600360101)...
Sony DSR-45 Mini DV VCR Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
