Question about Cannon Office Equipment & Supplies
I have a Cannon LBP 1260 printer. I had a paper jam under the toner cartridge; I removed it and now when I insert the toner cartridge, I keep getting the message, No toner Cartridge.
I determined that the problem was with the cartridge; I had an old toner cartridge at home and installed it and the printer works fine.
Posted on Nov 26, 2008
No toner cartridge error in canon 2900
Had the same problem. This is what worked for me:
Switch off the printer, remove the power cable, remove the usb cable, wait for 10-15 seconds. Re-insert the cables, switch on the printer. Mine worked after that.
May 03, 2012 | Canon LASER SHOT LBP-2900 Printer
I had a cannon LBP2900 printer. IT has a problem of paper jam. It prints very well in A5 paper but hen i try to print in A4 paper, the paper gets jam. It also makes some cracking sound and i found some...
Without doing a complete disassemble, remove all covers, remove paper tray(s), remove ink cartridges (or laser cartridges...everything that is EASY to remove. Clean your rollers (may be gummed up a bit), remove all dust, dirt, grime, everything. My Canon printers are extremely sensitive to jams. As long as you keep it clean internally, you should have no problems. Take a look at this video about paper jams.
Nov 30, 2017 | Canon LASER SHOT LBP-2900 Printer
I have a cannon LBP 2900 printer and it keeps saying there is a paper jam but there is no paper in it. How can I fix this?
I also haave the same problem with the canon laser shot lbp 2900 even it is a new piece. so it is better never to use this product.
Jan 14, 2011 | Canon LASER SHOT LBP-2900 Printer
A paper has struck in printer so its not printing how to remove the paper
1) Open the top cover
2) Remove the toner cartridge
3) Remove any paper from the multipurpose tray
4) If you can see the LEADING EDGE of the jammed paper slowly pull it out.
This may be easiest from either the multipurpose tray side or from under the toner cartridge
5) If you can see the TRAIL EDGE of the jammed paper slowly push it through the printer until it comes out
Dec 17, 2010 | Canon LASER SHOT LBP-2900 Printer
Hello sir, one paper is jam in cannon printer. how solve this problem??
Take out all the cartridges then you are able to remove the jammed paper.
May 25, 2010 | Canon LASER SHOT LBP-5000 Printer
IT KEEP SAYIN RMOVE PAPER JAM
  1. Turn off the printer.
    Remove any paper trays. Inspect them for wrinkled or damaged paper.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  2. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
    If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though
    eplace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    1. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
May 02, 2010 | Office Equipment & Supplies
Paper feed is jamming ,I have not even gone through the original ink cartridges yet,so i haven`t done a lot printing
Things to do remove the papers jammed inside the printer.
  1. Please Turn off this Canon Pixma 2600 printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper or any piece of paper got trapped in the printer..
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Do it carefully with utmost care.
  8. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  9. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Before inserting the Toner or Catridge, please wipe the roller with cloth gently.
  10. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
See alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 16, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Says paper jammed but there is no paper jammed
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Jun 04, 2009 | Canon LASER SHOT LBP-5200 Printer
Paper jam
just remove all cartridge and u will find the stell plate wich is movable from there u can remove the paper
Mar 25, 2009 | Canon LASER SHOT LBP-5000 Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
