Question about Samsung HLN467W 46" Rear Projection HDTV
Samsung HCL4715W-has blue shadow
Approximately two years ago we had a color convergence-shadow area #B393222474 Auth AE001752393QU replaced. Thank goodness it was still covered under warranty as the repair tech said this would have costed over $700.00. Which picture tube has gone out again.
  • Terri Moore Nov 25, 2008
    Would it really cost $700 to have a repair person fix it or can you order the part online? Thanks so much for your quick response.
    Genius:
  • 2,920 Answers
Probably the green
Posted on Nov 25, 2008
  • Ronnie Houston Nov 25, 2008
    you can do the repair yourself shops have a huge mark up on parts over what they actually cost. you can order the part online from samsung
Our samsung HCl4715W tv is all connected right but our picture is scrambled where you see double exposure and the color is off. Can not find our manual. any suggestions?
The problem of your tv is the convergence. Projection tv set has a 3 colors red,blue and green this 3 colors must be properly lined up to look the video normal. When this 3 colors is not properly aligned the video will produce a double image of color or like a 3d or wavy. In order to fix this problem you should adjust it in the menu program of your tv you should move any of the colors to up or down, left or right if you cannot align the 3 colors the problem is the convergence ic it must be replace. To locate the convergence ic you should remove the back cover of your tv but be sure to unplug your tv, you will see this ic attached in a large aluminum plate it has a marking of stk--- and followed by a numbers. or you could contact a service technician do do it for you and save you from stress. Good day and best regards.
Jul 17, 2011 | Samsung HCL4715W 47" Rear Projection...
Blue image is ghosting and not lining up with other colors. Perfect focus is on but with "no sensor data" message at top
The tv have a problems known as a convergene problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergnce board,must be replaced to solved the tv picture convergence problems.Can u do basic things like take things aparts and install another things into it placed?Yes?Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The DLP tvs Samsung/Akai tvs used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Jan 14, 2011 | Samsung HCL4715W 47" Rear Projection...
Samsung three colors on screen, out of focus #hcl4715w
It is a convergence problem. The IC's (integrated circuits) or STK chips or the "guns". You have a red,and blue, IC's that provide all the colors. When the colors are out of convergence, you get ghosting or what looks like 3D pictures. I haven't been able to locate the part numbers for the IC's or STK chips but have located a convergence board. No luck determining if IC's are included (a phone call first to verify) but if they are, would make life much easier for you to install. Part # is BP95-00415H http://jr.partsearch.com/Part/Samsung/Samsung/BP9500415H/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HCL4715W
Typically, IC's cost around $10 or less. here is a link to a guy who provides pretty good instructions on replacing the IC's along with pictures.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Hope this answers your questions. Best of luck.
Greg
May 31, 2009 | Samsung HCL4715W 47" Rear Projection...
I have a samsung 50? inch projection tv i bought approximately 4 years ago. We are overseas and now the picture shows in double, as if i am watching 3d movie. I would love to keep it but how would i be...
maybe you can have someone send the parts you need and maybe you can find your model and chassi number here for the schematic
http://www.eserviceinfo.com/equipment_mfg/Samsung_2.html
but it sounds like you will need convergence IC's to fix the color alignment , but some bad resistor or resistors will most likely be involved
here is an example of the convergence IC's
http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
and they can be ordered from an electronic parts supply store
Dec 01, 2008 | Samsung HCL4715W 47" Rear Projection...
All screen is red
IF THE SCREEN IS ALL RED WITH VIDEO VISIBLE AND RETRACE LINES. ADJUST SCREEN CONTROL IN THE FRONT FOR THE RED TUBE ONLY. TURN CONTROL COUNTER CLOCKWISE. IF THAT DOESNT DO IT THE TUBE CAN BE REJUVINATED.
Nov 19, 2008 | Samsung HCL4715W 47" Rear Projection...
Red a green shadows on most objects!
use manual convergence to re align the colors. the owners manual tells you how to do this. No manual go to samsung. com in the FAQ section
Oct 11, 2008 | Samsung HCL4715W 47" Rear Projection...
Hcl4715w samsung
you need to replace both the convergence ICs number STK392-040 you can get new replacement ICs at the link I am posting and they include free instalation instructions with pictures and free tech support. Heres the link.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection CRT problem
your screen and focus controls need adjustment to acheive a good grey scale picture the adjustment are not on the crt neck boards.(focus block)
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
Convergence
Replace both convergence IC's part# STK392-040. Also check for burnt/discolored resistors nearby.
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HLN467W 46" Rear Projection HDTV Logo
Jerry Greenberg
Jerry Greenberg
