Sound is good, the area where the crack is at has diffrent color lines. what part needs to be replaced?
The set is finished- sets like this use a display panel- it is the entire front screen unit and a sealed unit at that.
Cost of the entire panel unit even if available will cost more than the set did when new ( not counting labor to remove and replace it).
Buy a new set and note all LCD and Plasma like sets have this issue as the display panel is very fragile.
SOURCE: My Vizio picture went out and tv made a loud
Most likely the TV has a power supply related problem. It's very possible that it maybe a bad capacitor or transformer on the power supply board that made the loud noise.
But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. If by chance the TV is still under warranty, go that route.
2. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flashing codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
SOURCE: tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
SOURCE: vizio P50HDTV 10A, Replaced power
It might have got a smallpoer surge and if you unpulg the set fromthe wall that should rest everthing back to normal, also check the inpu voltage going to PIP module.
