Question about Bosch 11236VS Rotary Hammer
BOSCH 11236VS HELP ME WITH A PROBLEM
BOSCH 1123VS. DRILL BIT WANT DRILL WHEN I DRILL THROUGH CONCRETE, IT WILL HAMMER BUT NOT DRILL. I TOOK THE TOP OF THE DRILL COVER OFF AND THERE IS A SMALL GEAR WORN. PLEASE LET ME KNOW HOW I CAN AQUIRE A PARS MANULA SO I CAN ORDER THE PART I NEED AND WHO DO I ORDER IT FROM THANK YOU. ACME PLUMBING.
DENNIS DAVIS.
    President:
  • Bosch Master
  • 1,378 Answers
I order parts for my Bosch tools at WWW.toolpartsdirect.com. They have the parts lists also so it is easy to find what you need. Don't forget to order some bosch grease for your tool because you will need to carefully wash-out all the old grease with metal bits. Good luck with you repair. Enjoy
Posted on Dec 16, 2008
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
How to take knob off bosh 11236vs
Turn lever to the right until it stops, then push the red button in with a screwdriver and at the same time turn the lever clockwise a bit more until it stops. Wiggle lever and it will come out.
Nov 19, 2013 | Bosch 11236VS Rotary Hammer
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
The chuck has been pulled off. Whats the easiest way to reinstall it on my Bosch 11236vs Hammer Drill?
The chucks on the 11236 are designed to be removed, if you were not aware of this it may look like the tool has failed, it has not. To replace the chuck set the chuck back on the shaft of the tool, grip the outer collar of the chuck and rotate it counterclockwise while pushing down .The chuck will drop into a set of grooves on the shaft and lock there, give it a wiggle after to make sure its seated. Sometimes it takes a couple of tries to get it. To remove it just grip the collar turn counterclockwise and pull up, the chuck will come off.
Nov 22, 2010 | Bosch 11236VS Rotary Hammer
Bit will not lock into chuck. Ball inside chuck is stuck in "in" position, Bit slides all the way in and out w/o engaging the ball.
Open locking sleeve, clean the inside with a good "rust type cleaner" WD40 if you can't find anything else, let it sit overnight, I suggest doing this 2 or 3 times, leave tool with drill end facing down. Clean out with small round wire brush, lubricate with white grease.
Oct 08, 2010 | Bosch 11236VS Rotary Hammer
My hammer drill won't hammer. larger corded model about 6years old. Used heavy about 3x per year.
when was the last time serviced?? If not recently then you would need to replace the o rings and look for other sticking/worn parts. Give me the exact model number and I will try and find you a breakdown and a rebuild kit. They are not that bad if you are handy with tools and take your time. Let me know
Mar 16, 2010 | Bosch 11236VS Rotary Hammer
Switch problem, where can i get new one
www.toolpartsdirect.com
just make sure you have the correct model...i linked it to the bosch 11236vs
you can also get it directly from bosch
the part number your looking for is 2607200578
Sep 26, 2009 | Bosch 11236VS Rotary Hammer
BIT FALLS OUT/ WON'T TURN
try pulling the chuck back at the same time turning the bit while installing it should drop into place release the chuck,then make sure the lever just in front of the trigger is switched over to the rite side to use the hammer action.hope this helps
Jun 20, 2009 | Bosch 11236VS Rotary Hammer
Chuck came off of drill on a Bosch 11236VS hammer drill
Have you pulled the collar to release the pressure on the steel balls. Just pull the collar usually forward and slide on the shaft and then release and twist till it locks. Let me know if I can help further
Jan 07, 2009 | Bosch 11236VS Rotary Hammer
Bosch 11236VS Rotary Hammer Logo
682 people viewed this question
Top Bosch Drills Experts
John Trevino
River bottom
paulcarew
Are you a Bosch Drill Expert? Answer questions, earn points and help others
