CRT MONITOR DISPLAY PROBLEM
Horizontal size is not expanding as much to cover the full screen even after increasing H-SIZE to the largest value.
  • 65 Answers
1.Change TIP 122 Check It's related spears
2.change Flyback cap
Posted on Nov 27, 2008
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
My monitor's image size is getting small horizontally i turn on my monitor and it get back actual after 5 minutes while it's working? and the brightness is also so much increased even my panel brightn
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
a computer needs its power and data to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Nov 24, 2011 | HP Compaq FS 7550 17" CRT Monitor
My screen appears horizontally expanded
If your monitor is crt type, on its menu control, goto menu setting look for something that will adjust horizontal width. Or set the adjustment on Display setting in windows.
Apr 10, 2009 | Computers & Internet
Less H-width for higher resolutions
this is not the electronic problem, this monitor is made to support such (800x600) resolution.
Dec 17, 2008 | Compaq 7500 17" CRT Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Width of picture increase
Have you checked your display adapter settings? Check the display settings in control panel. Make sure you are viewing the screen at a decent resolution. 800/600 or larger. Let me know what happens. Good Luck, Tim
Feb 14, 2007 | LG Studioworks 563N 15" CRT Monitor
56v-Screen shrinked horizontly
You need to service your monitor. Give it to an authorized service center.
Dec 15, 2006 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
505 people viewed this question
Alun Cox
David Payne
David Payne
