Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Changed Electronic control on Kenmore dishwaser
With replacement Whirlpool part. Kenmore 66516919001 was stuck on 76 minutes and would not continue. The new board doesn't work right either, runs for a few minutes and then drops to 1 minute and drains, then clean light flashes 7 in a row. I tried the reset procedure all lights come on I let it run its cycle, which clears blinking light. Could the new board be installed incorrectly, is there any difference in the part.
  • lynnhb1 Dec 01, 2008
    I tried this, the motor runs. I got a code of d1 , do you know what this means?
    Sergeant:
    Champion:
  • 311 Answers
Sounds like wsh motor is not running. Test cycle by pushing in order: hi temp, air dry, hi-temp, air-dry. All lites come on and unit will run. Should hear motor running when 'washing' light is on. If not then motor is bad or something stuck in impeller area. Please leave feedback.
Posted on Nov 28, 2008
Kenmore elite dishwasher stops in mid cycle green clean light flashes 8 times pauses and then flashes one more time
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control.
May 23, 2013 | Kenmore Dishwashers
F1 alarm started last night. Turned off circuit breaker overnight, tried today and still continues to alarm. Repairman wants $76 dollars to walk in the door. Please help
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Nov 15, 2010 | Amana AOES3030 Electric Single Oven
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool gas range m#SF114pxsq1 diplays an F1 error code
HI. This is a basic Electronic Range Control Board failure code. I would advise to try a hard reset. This may correct the fault, if the damage is not severe. Simply unplug, or shutdown the appropriate circuit breaker for five minutes. After the five minutes have passed, kindly re-introduce power to the unit once more. Try to preform a baking cycle. if the code continues to illuminate during the attempt to operate the range, simply replace the main electronic control board(ERC or Clock).
Nov 16, 2009 | Kitchen Ranges
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Whirlpool dishwasher gu1500xtls2
HI, this is a control fault and you can confirm failure by shutting off the breaker switch or unplugging for 5 minutes. if the unit continues to malfunction after the 5 minute reset, you will need to replace the electronic control board.
Electronic Control board part number----8534866
May 20, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Electric Self Cleaning Stove 790.95660103 Oven On All The Time
There is a relay in the electronic control of your range that is stuck closed causing power to be applied to the element continuously. The relay is an integrated part of the control and isn't replaceable.. The repair would be to replace the electronic control(clock).
Feb 24, 2018 | Kenmore Ovens
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
232 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
