Question about Whirlpool Washing Machines
Whirlpool Washing Machine AWM 029 is not draining
The full wash cycle is not completing and as a result, the water is not draining away
  • gpeebles Nov 25, 2008
    Have already tried this and so it would appear there must be a problem with the pump. Do you have any other advice? Thanks for your help.
I have a similar problem with a whirlpool awm 029 and have tried to remove the plastic trim to get at the filter but without success. I turn what appears to be the relaease mechanism two clicks anti-clockwise and the plastic comes off in my hand with no discernible access to the filter. Water still drains out.
How do I get into the filter to check it?
Posted on Dec 26, 2009
  • Whirlpool Master
  • 3,463 Answers
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Posted on Nov 25, 2008
  • Barry Coates
    Barry Coates Nov 25, 2008
    Have you checked the filter?
    usually located at the bottom front, there may be a plastic trim you need to remove at the bottom of the washer.
    If filter clean you should be able to hear the pump going.
    You could also try blowing down the drain hose (clean the end first), and see if that is clear.
    If all else fails then I suggest a new pump
    Good luck.
We have whirlpool awm 029, that keeps stopping mid cycle, will restart when turn on / off switch
No cold water will stop it b4 rinse change water valve or turn cold water on all the way
Nov 20, 2016 | Whirlpool Washing Machines
Whirlpool AWM 312 front loading washing machine motor does not spin.
Hi Sachinl, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 03, 2016 | Whirlpool Washing Machines
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHirlpool 1600 Washing Machine AWM 8163 model. The letter ''P'' appears on the display screen and the washing cycle will not complete. Tried the other cycle and unfortanetly the motor sounds but the...
Removed the top cover of the machine and cleared out the hoses and the plastci chamber, which was full of limescale which had built up and also unscrewed the front outlet cover, again that had become clogged up with alsorts debris. Now it works a treat.
Dec 12, 2009 | Whirlpool Washing Machines
Washing machine not draining
hi,
problem is with the thermostat, replace it.
thank u
Jul 23, 2009 | Washing Machines
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Jul 26, 2007 | Whirlpool AWM5145/2 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
398 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
