Question about Car XR9000 Two-Way Confirming Remote Start and Security System wit
Vehicle shuts off after remote start
After I tremote start the vehicle, it runs for about 20-30 seconds then shuts off.
  • w2willi Apr 29, 2009
    04 dodge ram. same problem. can the brake wire cause this
    Problem Solver:
  • 13 Answers
I will need to know the make and model of your car to answear this possitively but this sounds like a problem with your bypass module. That is if your car has a immobility system. an easy way to check this is stick your key in the ignition "Do not turn the key" just insert it in the ignition then hit the remote start. if the car does not shut down that is where your problem lies. if the car still shuts down then your problem is due to either a bad brain or faulty wiring.
Hope that helps,
Posted on Dec 04, 2008
I have a 2004 Ford Ranger and when I try to remote start it, it starts but it sounds like its trying to start it again and then shuts off
If the truck starts fine with turn of the key in the ignition,look into finding the problem with the remote starter system.
Components maybe faulty or not proper.
Module.( Hidden underneath, usually somewhere under steering column area)
Receiver/Transmitter.( Mounted inside vehicle windshield )
Switch.( Under Hood,usually on the top radiator support bar )
Wiring.( all connected to the Module )
Fuse / Relay.
Remote / programming/ remote battery.
Connections that maybe loose,corroded, loose or wrongly connected.
Its also possible your vehicle might need a by pass module to connect with the remote starter module, to enable vehicle starting by remote.
Have a nice day.
Apr 17, 2016 | Vehicle Parts & Accessories
Remote start works but shuts off right away
When you say right is as soon as the vehicle starts....or is it 10-15-30 seconds later? Is this a factory remote start? If not, and you installed an aftermarket one, what is probably occurring is that your factory anti-theft system is seeing the vehicle running without the key in the ignition and activates the immobilizer which shuts down the vehicle. Aftermarket remote starts require adapter electronics to bypass the immobilizer until the operator enters the vehicle and inserts the key. This is why most aftermarket alarm systems are installed by trained pros.
Nov 05, 2013 | Dodge Grand Caravan Cars & Trucks
2009 dodge grand caravan 3.8l. remote starts vehicle then shuts down after 5 seconds whats the solution
sounds like your factory alarm is not working with the remote starter. it happens a lot with the new cars. check the BCM that runs the factory alarm.
Dec 15, 2012 | 2008 Dodge Grand Caravan
I live in Michigan. I have a Viper remote start and security system. When the temperature is below 30 degrees I have the following problem. When I try to remote start my vehicle, it starts, runs for 2-3...
The remote start has has a status option for it to know when the car has started and for it to keep it running. Most techs do it the lazy way and just set the option to voltage sense. You have to have a tech hook up the tach wire to the remote start and then program it for tach sense.
Jan 16, 2011 | Remote Start System
Cannot get to work with manual transmission please help with any ideas?
There are several steps necessary for the unit to function with manual transmission. Now,the unit comes programmed for manual transmission out of the box. Next, the neutral safety wire (thin black with white stripe) MUST be connected to the parking brake wire. Also, the tachometer wire MUST be connected. Check the neutral safety switch as well. Did you install a clutch bypass? All that is left is the system setup for remote start: Start the vehicle with the key,make sure all doors are closed, put the vehicle in neutral, press on the brake, apply parking brake, release brake, within 15 seconds remote start the vehicle, the parking lights will flash to confirm the remote start activation, turn the ignition off ( the vehicle should stay running.Exit the vehicle. Arm the alarm ( the vehicle should shut off). You are now able to operate the remote start. This process must be done each time you exit for the remote starter to function on a manual transmission vehicle. Don't worry ,you'll get used to it.
Oct 12, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My 2007 Ford Edge W/ Mars 22 remote start will start for 2 seconds when you hit the start button then shut off then start again then 2 seconds later shut off and will repeat this 2 more times, then will...
put your key in the ignition leave it in the off position, push your remote start button, if it starts then it has something to do with the transponder bypass "key in the box" or the loop around the ignition switch under the plastic cover
Feb 23, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Car starts but shuts off after 15 seconds
Here is the link to get the manual.
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Feb 10, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Vehicle will not shut off after key is removed.
try starting it with the key and then try to shut it off with the key...
Jan 10, 2009 | 2003 Chevrolet Tahoe
Car XR9000 Two-Way Confirming Remote Start and Security System wit Logo
535 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
