LG DVD PLAYER THE FUSE IN SIDE KEEPS BLOWING I WENT OUT AND BOUGHT THE SAME FUSES BUT STILL HAVE THE SAME PROBLEM
  • 98 Answers
Depending on the model most LG dvd players use SMPS Power Supply (Switch Mode) when a fuse pops it could be a regulator causing the reburst of replacement fuses better off buying the SMPS as a whole from the Vendor
Posted on Nov 25, 2008
Blows fuses
Hi,u need to have the powersupply replaced .
Oct 13, 2013 | Samsung DVD-V1000 DVD Player/VCR
Shortage somewhere interfering w/ cooling fans for engine
First unplug both the cooling fans then take a jumper wire one from the positive side of the battery and one from the neg. side and test each fan to make sure they are working properly, it is possible that one of them is froze up. That would keep blowing the fuses. If both of them are okay then check the sensor on the radiator, if that is ok then u have a short in the wiring
Jun 02, 2010 | 2002 Chevrolet Impala
The fuse in the power cord has been failing. We've been trying a 0.315amp fuse which keeps blowing. what size fuse should we use?
Well, if it keeps blowing, and it blew out the original, then its trying to tell you that somethings wrong. I would say that you need to replace the main transformer in your power adapter, but it would be waaaay easier to just get a new one.
If you just increase the amperage of the fuses your using, you will surely damage your player.
Mar 25, 2010 | RCA DRC629N Portable DVD Player
I replaced the fuse in my memorex dvd player and it keeps blowing the fuses
this is because there is a more major problem than just a fuse i'm affraid the fuse is blowing,trying to save components but the more times you replace the fuse the more damaga you could actually do, it works like a domino affect,sorry but needs pro help
Jul 19, 2009 | Memorex MVD2042 DVD Player
BLOWN FUSES IN THE POWER CORDS ON MY PVS72901
you can get fuses from almost any electrical shop, just take the blown fuse with you, give it to the shopkeeper and ask for a new one. The fuse might be blowing because,
-if you have a fan it might be blocked,
-the DVD Player gets switched on and off,
-The device its connected to might be malfuctioning.
HOPE THIS HELPS!
Jul 13, 2009 | Audiovox PVS72901 Portable DVD Player
LG DVD PLAYER THE INSIDE FUSE KEEPS BLOWING IVE BOUGHT THE SAME FUSES BUT STILL HAVE THE SAME PROBLEM
1. THERE SHOULD BE A SHORT CIRCUIT SOMEWHERE
2. THE WATTAGE YOUR DVD PLAYER IS CONNECTED TO IS HIGH
3. THE FUSE RATING IS LESS THAN REQUIRED OR NEEDED
4. YOUR HOME VOLTAGE IS LOW
5. SOLUTION, TRY USE A VOLTAGE STABILIZER BETWEEN YOUR SOCKET/POWER OUTLET AND YOUR DVD UNIT.
THIS SHOULD SOLVE ISSUES RELATED TO VOLTAGE OR CURRENT.
6. CHECK THE NAME PLATE FOR YOUR LG DVD PLAYER OR MAINTENANCE MANUAL FOR APPROPRIATE FUSE RATING AND CORRECT IF WRONG.
7. CHECK FOR ANY ABLE BRIDGING OR ANY METAL (EVEN IF IT IS A STRAND) CONTACTING TWO CIRCUITS TOGETHER.
8. CHECK MAYBE THE MOTOR DRIVING THE LASER HEAD IS BAD. COULD CAUSE THE FUSE TO BLOW DUE TO EXCESSIVE CURRENT AND INABILITY TO ROTATE.
Nov 25, 2008 | Televison & Video
Blowing fuses on vm9410
use a bigger fuse or a smaller one
Oct 10, 2008 | Jensen VM9410 Car DVD Player
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Feb 09, 2008 | Durabrand Portable DVD
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
Electro Med Services...
