BR400 FLOOR SCRUBBING MACHINE.The unit is not putting water down.The pump is working.Any ideas?
We contacted Karcher technical services and sorted the problem in two minuites.It was a "pinched " water feed pipe caught in the casing Thanks
Posted on Nov 28, 2008
I have dirty water coming from the machine jet system.What are the possible problems and solutions please?
Check the soap box. They tend to accumulate grim.
They can be removed, some easily, some with some struggle, but they can be removed.
Clean them with vinager. soak them in warm viniger overnight, then give it a good scrub.
Next, check that you don't have any clog in the water pump. its usually down at the front the machine near the floor. Open the hatch, and have some mops ready. clear everything there .
DON'T FORGET TO DISCONNECT THE MACHINE FROM THE POWER SOCKET.
Last thing, you could run the machine a cleaning cycle.
check this video. it helped be plety.https://www.youtube.com/watch?v=frEJhX9Sppw
How to Diagnose Washing Machine Drain and Pump Problems
Nov 08, 2015 | Washing Machines
Tip
How to Clean a Tile Floor and Grout when nothing else seems to work.
What you need is Cleaning Paste, a Scrub Brush, an Enviro Cloth and water. The picture shows a before and after. After years of mopping the floor with the traditional cleaning products, dirt had discolored both the tile and grout. I was down to needing to decide to start over by replacing the floor, or give it one last try. I had seen and heard about this product from a friend who I purchased the products from but I didn't really know if it was hype or truly something new that would work.
It restored my kitchen floor to like new! I never thought it would work but for the $50 it would cost in products if it worked, I wouldn't have to pay Thousands to put in a new floor.
I simply scrubbed on the cleaning paste using water and a scrub brush. Let if sit for a minute or two and wiped up the floor with my EnviroCloth. It took a little bit of time to do the whole kitchen but for me, it was definitely worth it!
I purchased these products from www.ChristineFrey.Norwex.biz
The Cleaning Paste has more then just floor cleaning possibilities.
on Jan 31, 2015 | Home
Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Oct 01, 2009 | KitchenAid Washing Machines
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
Dirty water comes out when I stop scrubbing. Floors remain wet.
Try one thing... the filter cover must be clicked into place. I thought it just sat on top, but it has to be pushed into place.
FWIW
Mar 22, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Frigdaire washer
ok no probelm..you have a front loader ,,first un plug unit,,now at your feet theres a toe panel,,3 screws remove them and the panel will slide down..now off to the cener left the thing with the little fan on front and the 2 black hose coming out,,1 hose lead out the unit to your drain and the other hose comes down from your tub...take that 1 of from your tub to pump but take it of from the pump ,,if its water in the unit ,,dip much as you can out and then put towel on the floor..now see whats jamming pump..im here for any questions,,,reverse to put together..onthejob
Jan 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Hoover floormate.
Can't do it. The machine vacuums in both scrub and pick-up. Sorry.
Kirk Thompson
San Juan,PR
Sep 01, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I cannot figure out how to use my cleaner floor mate
At the risk of giving a simplistic answer, let me go through the steps I go through every time I use mine:
1) Plug it into the wall
2) Take out the upper "hopper" and fill it up to the fill line with hot water
3) Put in the capful of cleaning solution (about 2 oz.)
4) Gently swish it back and forth, then put back into upper unit until it clicks into place
5) For best results, set the vacuum on Dry and vacuum the house first, then clean the lower "hopper"
6) Set the vacuum to Wet, put the scrub brushes on, depress the trigger and do overlapping strokes, a section at a time I depress the trigger on the push stroke, then release it for the pull stroke. I clean a section, then turn off the scrub brushes and go over it again without the scrub brush or touching the trigger (trying to pick up as much water as possible).
On average, when refilling the water/cleaner solution for the top hopper, empty and clean the lower hopper. When the floors are finished, completely clean that lower hopper or it will smell!
Hope this helps...
Jul 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
