Question about Bionaire BH3930 Oil Filled Radiator Heater
Heater won't turn on, the lights keep flashing.
I left my heaer on and when i returned the lights on it were flashing, i've got a Bionaire boh2513g . I turned it off at the plug for 24hrs thinking that might fix it but when i turned it back on the lights siply resumed flashing again and it gave out no heat. Any ideas?
  • Anonymous Jan 17, 2008
    1. yes problems same need a number to contact bionaire read there is a fault with this product and it needs to be returned if anybody can help i would be so gratefull FREEZING
HI There is a product recall for this particular model of heater, you can search the internet for details on how to get the item collected by Bionair and get a full refund, these are a fire risk.
Posted on Feb 08, 2007
SOURCE:
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
Unit shows service heaer light unless i manually turn pump on, what am i doing wrong
if pump is off and heater is on its showing you no water pressure
Dec 12, 2015 | Pentair Mastertemp Heater
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Steady Yellow Light
Is it an old model? Should you try to have it replaced?
May 18, 2017 | Holmes Products BH3955-U Bionaire Utility...
Heater won't stay on, I heard there was a recall on this item.
Hi and welcome to FixYa, I am Kelly.
I am only answering part of your question (Recall) so do not rate the post so other experts can help you with your heater won't stay on problem.
Your heater model is not one of the 4 models that were recalled.
The recall involves Holmes® models HFH6498-U, HFH6500-U and HFH6500TG-U and Bionaire® model BFH3530-U. The recalled heaters also have date codes beginning with 2604 through 3804 for all units, except for Holmes® model 6500TG-U, which has date codes ranging from 2604 through 4704. The model and date code can be found on the silver label on the back of the unit. The heater fans are 26 inches tall; come in all gray, two-tone gray, or black and gray; and have either the word Holmes® or Bionaire® printed on the front of the base.
See this link for more details:
http://www.holmesheaterrecall.com/
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
I have the bionaire oil heater boh2513g. I placed a towel over it to dry and I think it's went into overheating safety mode because the three lights are flashing but the appliance wont come on. Is there...
Turn the Master switch to OFF and plug the heater and leave unplugged for 30 minutes, That should give it time to reset itself. If it doesn't work after that, it's probably fried.
Mar 15, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
Can't get heater to restart using remote control & 2 small green lights on heater flashing on & off
Have you tried replacing the batteries in the remote control? That may be part of the problem.
If you have already changed them, unplug the heater for 30 minutes to allow it to reset itself.
Hope that solves your problem.
Feb 28, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
Bionaire BH3930 Oil Filled Radiator Heater Logo
2,270 people viewed this question
Top Bionaire Heating & Cooling Experts
Richard McDermott
Level 1 Expert
Vernon Taylor
deton8 von Splosion
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
