Question about LG VX-8700 Cellular Phone
LG VX8700 won't stay charged...
My phone dies without warning.
What's strange is, if I have two bars left and I top it off with a charge, the next time I turn the phone on it won't start up. Whereas, if I let the battery drain completely then charge, I have a better chance of the battery holding its charge.
My first assumption was that it was the battery. I replaced it, then a little over a week later, I started having the same problem again.
How can I determine whether it's the phone or the batteries?
  • nick_demayo Nov 25, 2008
    Thanks,
    As originally stated, I did replace the batteries and I am still having the same problem with it holding a charge. Before I spend another $40.00 on a battery, I was inquiring if there is anyway to test if there is something wrong with the phone.
    Thanks again.
  • missyg53 Feb 02, 2009
    I have the exact same problem and Verizon makes me really upset because they only want to sell me a new phone. I switched both the battery and phone TWICE and still have the same problem. However when Verizon replaces the phone under warrenty they give "used" phone. My best friend has the same phone and has no problems probably because her's isn't used.
I had the same problem with mine... I found that you must let the battery completely drain out; I was continuously jumping to charge my phone when it was down to one bar, and realized that upon doing this, the battery never fully retains its charge for as long as it will if you let it die out (blank screen; completely off).
I did this twice, and have not had a problem since.
Hope that helps!
Christina
Posted on Dec 06, 2008
    President:
  • 4,402 Answers
Replace batterys
Posted on Nov 25, 2008
My LGIP-430N won't hold a charge. I put it on the charger for a long period of time (5 hours) and it only has one bar in the battery indicator. I don't understand why it won't charge up and stay charged....
Ifthe cell battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 24, 2011 | LG Cell Phones
My Samsung Comeback will not charge. When I plug it in and it's turned off, the bars go up, as if it's charging. But when I charge it for a long period of time ( longer than usual for it to be fully...
Hey! My Sister has the same problem. T-Mobile said that it is the battery. There was a defect with some phone batteries. You can buy the samsung battery from T-Mobile for like 48$ of go to cellphoneshop.net to get it cheaper. works great and is cheaper to replace than 48$ samsung battery!!
Aug 20, 2010 | Samsung Comeback Cell Phone
My phone is completly charged and when i pull it off charge about half an hour after depending on how much i use it, it turns itself off and then when i try turning it back on the Lg start up comes on then...
The happy news is there is no problem with phone,the hardware of your phone is in good condition.The problem is the battery.The battery of the phone is dead.This a step behind Stone dead stage.Next state of your battery is stone dead.You can't even use it more.Now the phone Battery will act like charging.Your battery can take small amount charge only because it is dead..Even though you charge your battery for 2 days continuously it will stay for 30 min or 10 min depending the charge usage.
Solution for this is you have to replace it soon..Go to nearest shop and check this with their battery and buy it.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | LG KU990 Viewty
LG neon battery dies within minutes!
The same thing happened to me you have to take it back to LG and tell them to replace your battery or buy it from Radioshack. At&T gives cheap batterys.
Apr 19, 2010 | LG Neon GT365 Cell Phone
Battery Won't Stay Charged
well if you have recieved new batteries and they wont stay charged then the problem isn't the batteries apparently. It could possibly be that your charger has gone bad and isn't charging your battery all the way. I suggest buying a new charger and it should fix your problem and if it's not your charger then it must be the outlet supplying voltage to the charger going bad. More than likely you need a new charger cause it seems like its not getting the voltage it needs to charge your phone.
Jun 09, 2009 | LG enV VX9900 Cellular Phone
Lg ks360 battery problem,, charge it up fully and battery dies in 2 hours my phone is dead in the morning when i left it the night before with only one bar of the battery down. What can i do to solve this...
Im not sure if this goes for phones...
But I noticed that when you get something with a charger and you seem to over-charge it (Leaving it constantly plugged in or charging it for long periods of time after its fully charged) it actually makes the life of the object shorter....
It could be that because you've been leaving it over night to charge its been eating at the LGs battery...
But like I said, im not sure...
Obviously you can't fix something like that...
Jun 02, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Battery went dead
Most likely you have a bad battery you can check by taking out the battery and feeling on it if it is flat than its good if it has a bump on it than it is no good.
Jan 04, 2009 | LG VX-8700 Cellular Phone
Battery for LG VX8700
The little plastic notch (button looking thing) on the back of the phone, near the top slides up (use your fingernail) When this is done the aluminum plate on the back comes off. Then use your fingernail again to pull outward on the top-left notch of the battery.
Dec 25, 2008 | LG VX-8700 Cellular Phone
My LG Chocolate won't charge
seems like the battery is dead. just get a new battery
Oct 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
KU990 Viewty's battery loses charge very quickly
I saw on another forum two good tips.
1. Do not use a case with a magnetic clip.
2. Take off the battery cover and put tape over the two small etched squares that you can see one at each end on the inside of the cover.
I did this and up to now my battery has doubled its life. Still two bars after 1.5 days of medium use.
Terry
Mar 28, 2008 | LG KU990 Viewty
LG VX-8700 Cellular Phone Logo
723 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
