Question about Toshiba Satellite A100-S8111TD Notebook
Sound of my noye book is very low with a lot of noise
I have a 2004 ford f150 making a tapping noies can it be the cam phasers going bad
check oil level ---yes it can but tapping noise can be a lot more reasons --worn oil -low oil pressure--low oil level--rocker loose-worn or damaged lifter-worn damaged valves --timing chain --water pump--pulley --really anything can cause a tapping noise --try to isolate the area or sound and diagnose problem
Sep 21, 2016 | 2004 Ford F150
Why has it started knocking?
Knocking is pretty non descript as there are a lot of noises that are associated with an engine. A true knock is a very bad sign. However there are other noises that can be confused for knocking. One way to tell is the location of the knock. High or low on the engine. If it is high then it is not as serious and is usually associated with the valve train. Low knocking is the crank and pistons. Ticking sounds are more common and can be something as simple as wear on lifters etc.
Jan 29, 2016 | Cars & Trucks
Air conditioning on my 2010 Liberty suddenly stopped blowing cold air.what can I do?
Could be the compressor died. Look at it. Do you see metal shavings around the front of it(it magnetic and holds them in place), between the front plate and pulley? See oil around it. If so replace the compressor. Look at lines also, for oil. A seal or hose could have blown out.
Jul 30, 2015 | 2010 Jeep Liberty
Signs of awheel bearing going on a daf cf85 430 articulated lorry 2004 ?
Wheel initally with start making a washing machine noise or grinding sound when doing sharp turns the opposite of the wheel side as the outer race will generally go bad first. You may also notice the rim heating up due to friction. Grinding at low speed or a growling sound would dictate an inspection.
Mar 19, 2015 | DAF 44 Cars & Trucks
What is the huming noise comeing from the front of my avenger while driving down the road.
Tires out of alignment can make a humming noise but so can a water pump or alternator before it goes out. A parts store can hook up to your car and test the alternator quickly and eliminate that.
Jan 18, 2015 | 2011 Dodge Avenger
My 500gb wd "my book" is making weird noises and wont show up
The whirring noise is the heads trying to read hard drive and then the weird rubbing screech sound and not showing up in your pc. sounds like the drive is dead.
Jul 14, 2010 | Western Digital My Book Essential 500GB...
Shots coming out black or nearly black. I'm shooting in RAW. When I try and rescue them on photoshop they come out really grainy
Sounds like the shots are under exposed with the shutter speed to fast.
Are you shooting in low light and no flash ?
If so, reduce your shutter speed to something like 1/60 with an aperture of around F5.6 - F7.1 (these can be lowered if you raise your iso)
Obviously this will depend on the lens type and brand.
Your statement sounds like you are shooting in raw at a very fast shutter speed with a low iso (200).
The grainy effect is normally due to a lot of noise (high iso) which makes this sound strange to say the least.
Check your camera settings (menu) and turn on noise reducution, this will help in removing some of the noise.
Oct 31, 2009 | Nikon D40x Digital Camera
Low sound quality, lot's of noise
the recorder does have two mic settings, hi and low. the high is great for lectures and the low is for personal dictation
Jan 08, 2008 | Olympus VN-2100PC Digital Voice Recorder
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
