Question about La Crosse Radio Controlled Atomic Clock
My atomic clock (radio) is one day ahead and I don't know how to adjust it. Model #SCR120
5 Suggested Answers
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: Atomic Clock Daylight Savings
Your clock may need to receive a signal indicating the time change. You can try moving it to another room, or outside to see if it reads the signal. Mine didn't, so I removed the battery and reset the clock. It wasn't obvious how to do that and I didn't save the owner's manual but upon close inspection there was a tiny black button (that looks like where you would lift a cover for a battery) and pressing it allowed me to adjust to the correct time. It is a "Sharp" bought at Target a couple of years ago.
Posted on Apr 01, 2009
  • 308 Answers
SOURCE: my atomic clock jumped an hour ahead. how do i fix
DST was set in the wrong setting. Change it and it should correct itself overnight.
Posted on Mar 26, 2010
gopakumarg43
  • 74887 Answers
SOURCE: my La Crosse Radio controled
Hello
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
Ok.
Posted on Jul 31, 2011
Cannot adjust time on ohe atomic clock
Let it adjust itself, usually at next transmission time WWV in Hawaii reset several times a day every four hours or so.Thats my experience.
May 13, 2017 | ATOMIC Watches
Sony IFC-218 clock radio runs 8-9 minutes fast
Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
Don't expect this clock to set the time by itself. It is not an atomic clock.
Nov 29, 2011 | Sony Audio Players & Recorders
I have an "SKYSCAN" atomic clock. seven days ago I replaced batteries. Has not reset as of yet.
Hello
Get into this link. You can see the user manual for your Skysacn atomeic clock here. You can adjust your clock according to it manual. OK.
http://www.atomicclocksstore.com/skyscan-atomic-clock-manuals
Nov 11, 2011 | SkyScan 86709 Atomic Wall Clock
MODEL:WT-8005 CLOCK IS 1 HOUR AHEAD HOW DO I TURN IT BACK?
Check both of these
  • Daylight Saving Time Automatically Updates (DST) (On/Off Option) applies to both USA and UK
  • U.S. Time Zone Selection: Eastern, Central, Mountain, Pacific (applies to USA only)
  • Mar 15, 2011 | La Crosse Radio Controlled Atomic Clock
    My atomic clock jumped an hour ahead. how do i fix it?
    Mar 26, 2010 | La Crosse Radio Controlled Atomic Clock
    Atomic clock is 2 hoursfast
    You need to reset it to YOUR time zone. The default on this model is Pacific Coast time so you must be in the Central Time Zone (2 hours ahead of Central). Instruction manual should show you how to reset.
    Feb 09, 2010 | SkyScan 86742 Digital Atomic Wall Clock
    Atomic clock sky scan model 87801
    Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time. kindly gave your rating after you read this.
    Nov 07, 2008 | SkyScan 86709 Atomic Wall Clock
    Skyscan atomic clock
    press set button repeatedly -you get timezone mode and change your wished time zone
    and select your zone then press set button.
    Mar 08, 2008 | SkyScan 86709 Atomic Wall Clock
    Daylight savings time
    so long as the US atomic clock adjusts their daylight saving times then you should be fine check this link for some more details (about the scr 110 but seems to be basically the same) http://www.amazon.com/H-H-Scott-SCR110-Atomic-Clock/dp/B00004TZDN/ref=sr_1_2/104-1966292-9407907?ie=UTF8&s=electronics&qid=1173502881&sr=1-2 hope this helps :)
    Mar 10, 2007 | H.H. Scott SCR120 Clock Radio
    La Crosse Radio Controlled Atomic Clock Logo
    20 people viewed this question
    Top La Crosse Home Experts
    John
    John
    Are you a La Crosse Home Expert? Answer questions, earn points and help others
