My stem not recognising floppy drive.
Hi, This is Darla.
I connected a floppy drive to my system through "add hardware" option and I checked it and It was displaying message that it was working properly. But, it's drive icon "A" not appearing along with other icons like cd drive, dvd drive etc. In bios settings, floppy drive mentioned as "disabled". I was unable to make it as "enabled". Where I've been doing mistake I don't know exactly. How to rectify this problem to work my floppy drive as usual.
  • 189 Answers
Greetings Darla,
You should have to enable your floppy drive at the bios settings, in order to detect your floppy drive.
To change to enable at the bios just press enter on the disabled option then select enable, but don;t forget to save.
That will solve your problem, Thank you, hear you someday.
Posted on Nov 25, 2008
  • 849 Answers
IF IT HAS DETECTED THE DRIVE IT MEANS THAT SYSTEM IS RECOGNIZING THE DRIVE, CHECH THE DRIVE STATUS ON DEVICE MANAGER, ALSO TRY TO ENABLE IT FROM BIOS (PRESS ENTER KEY ON IT, OR +/- KEY TO CHANGE IT) AND RESTART SYSTEM.
Need driver
Floppy drives do not need drivers. Support is built into the operating system.
I assume that the machine is not seeing the floppy drive. Here are some possible solutions:
1. the drive is not properly plugged in to the computer.
2. The drive is defective.
3. The BIOS has not been set up to recognise the drive.
4. The cable is defective.
Dec 06, 2013 | Samsung (SFD-321B/LE) Internal Floppy...
Add floppy drive
What model Lenovo ??...
Because PC makers no longer include floppy drives in computers, many new PC users have never used one.
Nevertheless, there are many occasions when a floppy drive can be the most convenient form of file storage and transfer for small files.
On most Lenovo ThinkCentre PCs, a floppy drive is an add-on option and most packages do not include the device unless you specifically request it.
If you purchased a ThinkCentre PC without a floppy drive, you can add one to the system yourself and save some money vs. taking the system to a shop.
Shut down the ThinkCentre computer.
Disconnect the AC power cord and other peripherals.
Move the computer to a sturdy work surface.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Use your fingers to push inward on the two buttons on either side of the computer.
Lift upward on the front edge of the cover to open it.
Open the cover until it stands at a 90-degree angle to the computer chassis.
Disconnect the ribbon cable from the optical drive.
Lift up on the rear edge of the drive bay tray until you can see the rear of the CD/DVD drive.
Orient the new floppy drive so that the diskette slot faces down.
Connect the floppy drive cable to the motherboard.
Slide the floppy drive part way into the floppy drive slot.
While holding the floppy drive, connect the other end of the cable to the diskette drive.
Lock the ZIF connector on the cable, then slide the drive all the way into the slot.
Slide the blue drive lock downward to secure the floppy drive in the slot tray.
Close the cover and reconnect all cables.
Power on the computer.
The ThinkCentre BIOS detects the new floppy drive automatically and configures it as the "A:\" drive on your computer.
http://www-307.ibm.com/pc/support/site.wss/MIGR-51497.html
Lenovo support
Sep 13, 2013 | Lenovo Computers & Internet
Hi, I have ViewSonic VX2235wm-5 22"
It appear the monitor has been connected to another system unit than the default. disconnect the entire systems and reconnect altogether, restart the computer to allow the unit to recognise the new monitor. should diplay possible soluiton, else follow the instrcutions below
1.locate the control panel where the options of systems setting is displyed.
2. a click should dispaly a list among which is device speaker options
3. the computer speaker could be updated by clicking to install drivers or codes acquirable from the network.
alternately
1. click on the hardware icons located after locating and clicking into control panel.
2. on the list of add delete hardware provides the option to attempt to delete the speaker codes
3. a delete of the speaker drivers on system restart would prompt the user to update the speakers. A click on the prompt should acquire the necessary installation kit patches from an internet connection if any.
Dec 06, 2010 | ViewSonic VX2235WM Monitor
My floppy drive does not seem to recognise that a floppy disk is inserted...after inserting a floppy disk and trying to run it ......it says ' please insert disk into drive A' ? any advice would be much...
Hello there!
Well, you 1st should check is your floppy drive properly insterted into your pc mb. Open your hardware check the joins on your FD(floppy drive) if thats ok, assemble the box. Next move is to check is your FD even enabled in ps BIOS. Open your bios acess general settings, and you should find setting flopy disc 1,28~ enable/disable.
After that if you still experience problems you should thinking about usage of usb pen drives, since floppy drive systems are really outdated, as I know there never been any drivers for that system , so those steps should solve your problem.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Samsung SFD 321B (SFD-321B) Internal...
My floppy discs will not come on
Throw the drive away and use a rewritable CD. There is little point using 1.44Mb floppy diskes when you can get 700 Mb on a CD and they are cheap.
Jan 10, 2010 | Microsoft Windows Vista Ultimate Edition
WD Elements USB drive not recognized
Try going to Disk Management and see if they show up there.
  1. Click Start
  2. Right Click My Computer
  3. Click Manage
  4. Click Disk Management
If your computer is recognizing a mass storage device they should show up in disk management and you can just assign them a drive letter.
Sep 15, 2009 | Western Digital Elements powered by WD 320...
External drive shuts down the Toshiba 460CDX/2.1. OS is 2000. I do not have Admin rights to add Hardware, the Admin is no longer available. The CD writes does not write to a CD only plays CD's. I need to...
The external cd drive should be having both CD and DVD options, that is Combo Drive or Super CD Drive where you can write all your data on to the DVD - eitherway it can be done. You can copy the data from DVD / CD on to your toshiba laptop.
Best solution is replace the exisitng laptop to a latet one with Vista option. Will solve your probllm. Otherise try to contact the local authrozed hardware engineer to assist you in solving this problem.
Good Luck.
Jul 15, 2009 | Toshiba PA2611U External Floppy Drive
Computer does not detect a Alps Electric Co. Floppy drive
check the data cable and power cable,does the light in the floppy stay on if so you have the power cable backwards.is the drive connected ot the right end on the data cable. if the answer to these are yes then you have a bad drive.
May 23, 2009 | Alps DF354H (DF354H168) Internal Floppy...
How do you get a computer out of preparing to run system set up? it stays stuck there
Before you start looking at reinstalling Windows you need to back up your important data – just in case anything goes horribly wrong.
Reinstallation loadTOCNode(1, 'summary');
Reinstalling from Windows
If you are able to get into Windows then you should start off by putting your Windows CD into your CD-ROM drive. Close down the automatic pop-up screen that appears when the disk autoruns and then open Windows Explorer. Point explorer at your CD-ROM drive and in the root of the drive you will find a file called SETUP.EXE. Double-clicking this file will start the installation of Windows. Skip to ‘The reinstallation procedure’, below.
Reinstalling from DOS
If you can’t get into Windows then you are going to need to use your boot disk to see your CD-ROM drive. You should have a boot disk already – if not then you should elsewhere in this article for information on creating one. Once you have this disk you should boot your computer with it in your floppy drive and restart your PC. Once the disk has booted, put the Windows CD in the CD-ROM drive, switch to the relevant drive (by typing the letter of the drive followed by a colon, such as D: or E:, and pressing [Return]) and then type SETUP.EXE and hit [Return]. Windows will now start reinstalling itself.
How to create a boot disk if you can’t get into Windows
Boot into DOS (press [F8] on startup to bring up the boot menu). Put a floppy in your drive and type format a: /s. This will create a bootable floppy disk. The next stage is the crunch point – you need to find the system-configuration file for your CD-ROM drive and copy it to your floppy disk.
Next you need to copy the Microsoft CD extension on to the floppy disk. Enter COPY C:\WINDOWS\ COMMAND\MSCDEX.EXE A: and hit [Return]. If this file isn’t there, it’s corrupted, so you need to find it. To do this in DOS you should type DIR /S MSCDEX.EXE, to search your drive. Once you find it, copy it on to your boot disk.
Next, make your floppy recognise the CD drive when it boots by creating CONFIG.SYS and AUTOEXEC.BAT. In DOS type A: to take you to the floppy drive. Next, type EDIT CONFIG.SYS. Type in device=< 'drivername'>.sys /D:mscd001, where 'driver name' is the name of the .SYS file from step two.
Save your CONFIG.SYS file. Next we need to create the AUTOEXEC.BAT file. Create that file by typing EDIT AUTOEXEC.BAT. Once this file comes up you should type MSCDEX.EXE /d:mscd001. Save the changes out to your disk.
uparrow.gif loadTOCNode(1, 'summary');
How to create partitions in DOS
FDISK is a powerful utility, and relatively straightforward to use. Remember that you’ll lose all your data as soon as you create a new set of partitions, and you’re away…
Boot from your floppy disk and make sure you can see your CD-ROM drive, as you are about to leave your old setup. Once happy, type FDISK to start Microsoft’s partitioning program.
Select option 3 to delete partitions and delete everything. Once you’ve done that you can create your partitions again. Select option 1 and then 1 again to create the primary partition to the size you specify.
The next step is to create your extended partition. Select option 1 followed by option 2 to start creating this second area. When prompted you should make the extended partition use all the space left.
The last step doesn’t actually create any logical partitions – you have to create these yourself in the extended partition. FDISK will automatically prompt you for the first one, just set it as big as you want.
Finally you should check that all the partitions are set up as you want them by selecting option 4 from the main menu again. Once happy with your setup you need to re-boot and then format your drives.
Reinstalling loadTOCNode(1, 'summary');
What you need
- 45 minutes of free time.
- Your Windows Product Key.
- Another blank floppy disk.
Don’t forget!
First, insert your boot disk, switch on and ensure your PC is set up to boot from the floppy drive – if it isn’t, enter your BIOS, select your floppy drive as the first bootable drive, and save your changes and exit. You should be presented with a menu. Choose the option to start with CD-ROM support.
Next you choose your set-up options. ‘Typical’ is the normal choice, ‘Portable’ is for installing Windows on a laptop, ‘Compact’ saves disk space by not installing optional components and ‘Custom’ is ideally for advanced users. We’d recommend you choose Typical.
During the next stage of the installation Windows installs software drivers for any plug-and-play devices you have attached to your system. After that, various Control-Panel settings are decided. You need to choose your geographical location in the Date and Time Properties dialog box.
Next you need to reinstall your monitor drivers. The Add New Hardware wizard will appear and try to locate drivers for your monitor. If you’ve got them on CD or floppy then put the disk in now and select Let Windows Search for Drivers. If you haven’t got any handy then you can choose Display a list of drivers in a specific location. Choose the default plug-and-play monitor.
The default monitor will get you into Windows, but limit you to 640x480 screen size with 16 colours. Once you’ve installed your monitor driver, install your graphics-card drivers. That’s it, Windows is reinstalled! Now it’s time to turn to move on into the post-install phase…
Post install loadTOCNode(1, 'summary');
Finally, your installation is complete and you’ve got a working version of Windows. A quick look at your Windows folder will probably reveal it’s about half the size it used to be, which means your PC is not only going to run faster,
Finalising hardware settings
To find out exactly what Windows thinks you’ve got installed, right-click on the My Computer icon and choose Properties. This will bring up the System Properties dialog box. Switch to the Device Manager tab and have a look to see if all your hardware is listed.
If a device has a yellow triangle with an exclamation mark next to it then it’s got a problem. Highlight the device and click Properties to get more information about what’s wrong. It’s usually the case that reinstalling the software drivers from your backups will solve the problem. Occasionally, if Windows is being really stubborn, you might need to remove the device from your hardware profile altogether and reinstall it through the Add New Hardware Control Panel before it starts to work.
It’s all over
, you now have a fresh installation of Windows. Once you’ve set your system up you might like to consider creating a drive image. Next time you want to reinstall Windows you simply copy this back on to your C: drive – this gets the job done in half the time and without the worry of setting it all up again.
Reinstalling your hardware
Run Add New Hardware from the Control Panel and Windows searches for plug-and-play devices that aren’t properly installed, producing a list like this.
Aug 21, 2008 | Computers & Internet
Floppy problems
please try by change the data cable.if the problem persist than you have to change your drive.
Apr 10, 2008 | ASUS P4P800-X Pentium Motherboard
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
