Question about Motorola Mobility V400
Sound settings need to find the sound settings, because i am unable to he the other person speaking, it is very low. it's not the speaker as that is new
  • 30 Answers
When you are talking to the other person the volume keys are the keys on the left of the phone push the up button. but it could be the speaker because the v400 was known for the speaker becomeing faulty i fixed mine from these instructions. http://www.howardforums.com/showthread.php?t=633428
Posted on Aug 24, 2007
I hear the backgroung music fine, but I can not hear them speak.. How can I fix this? Thanks! I havesony surround system model # dav-hdx589w
Sounds like the center speaker is not working, or the center volume setting has been set too low.
a) First check power connection to speaker. If you have removable power cords on the speakers, try switching them around.
b) Then check settings for speaker setup in receiver. Check manual on this procedure.
c) Sometimes the input source may not be sending the information. Check this connection next.
Sep 16, 2011 | Sony DAVHDX589W Theater System with...
What is dynamike gain cotrol on a cobra cb radio
Dynamike Gain Control varies the microphone sensitivity. When set fully clockwise, it is very sensitive - and will be able to "hear" background noises easily. This position also can cause your voice to be distorted or garbled when approaching maximum under the right conditions as well as causing "bleed over" to adjacent channels. When set to minimum, you will need to speak clearly and directly into the microphone to be heard. Most people find a setting somewhere in the middle works best.
You should adjust the level to suit those that are listening to you by asking them if it sounds OK. This prevents them from having to turn their volume down whenever you speak. In a "one-to-one" conversation it is not as noticeable. The trouble comes when 3 or more are conversing. The third person's audio may be low or normal - and the listeners set their radio's volume so that they can hear that person easily. Then you transmit with booming mic audio and everyone scrambles to turn down the volume to save their ears / speakers. This can be very frustrating for the others having to constantly adjust the radio volume whenever you speak.
I hope this helps and good luck. Please rate my reply - thanks.
May 18, 2011 | Cobra GPS
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
Why i speak to people,the person on other side sounds muffled and like charlie browns teacher?
your signal sounds like it isn't strong enough or you burnt out the speaker get a new phone
Sep 04, 2009 | T-Mobile Dash Smartphone
Other person can't here me speak
It definitely is not the speaker but the Microphone; we got to have tested no smart way out.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 18, 2009 | Cell Phones
I have a Yamaha HTR-6130 connected to a Samsung 550 plasma tv. I find the speaking sound in movies and tv programing to be too low relative to other background sounds. Any way to raise the relative...
If your running the receiver in 5.1 using a center channel, go into the main menu of the receiver and select "speaker settings" toggle to "center channel" and adjust the gain to taste. If you need more help, post a comment and I can help you some more
Jun 25, 2009 | Yamaha HTR-6130 Receiver
Logitech Quickcam Deluxe causes speakers to go out.
Have you set your cam up on skype
Go to TOOLS, then OPTIONS, and click on Audio Settings
and set the Microphone and Speakers
to the computer Audio Card.
Then click on the Video Settings.
The camera if installed properly
will come up and show a picture.
Then on the bottom of the page click on Save.
program
Jan 26, 2009 | Logitech Webcam
Works only in speaker mode
mine does it from tme to time and so does my friends.....unusual solution but banging the phone on a table quite hard a couple of times really does the trick.
Aug 22, 2008 | Sony Ericsson K800i Cellular Phone
Microphone problems
Go to your control panel in windows, you can get there from the start menu no matter what version you are on.
In the control panel, double click on Sound. In the new window, click on file and settings... or advanced I cant remember exactly which as I am using vista. There you should be able to select "Recording". Click ok.
Now you should be able to see where it says microphone, with a volume bar and so on. Put a check in the "Mute" box. This will not completely mute the microphone, it should only make it to where you will no longer hear it on your speakers.
Try talking to your friends now... It should work! I hope this helped to fix your problem, if not, let me know and we can try something else.
Apr 27, 2008 | Packard Bell (030069) Sound Card
Motorola Mobility V400 Logo
145 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
