Question about Acer Computers & Internet
HOW DO I INSTALL A PROGRAM INTO MINI LAPTOP WITHOUT A DVD DRIVE?
  • 849 Answers
Copy all your desired programe to pen drive/usb/flash disk and install them
Posted on Nov 25, 2008
How do i install a program so i can use my DVD on my laptop
http://www.wikihow.com/Install-a-Program-from-a-CD-or-DVD-on-a-Mini-Laptop-Without-a-disk-drive-using-Daemon-Tools
Sep 07, 2014 | Computers & Internet
How to reset administor password on Dell mini laptop
Forgot windows password? Don't worry about it, when I forgot the password, i remove the password by the following steps,
Step1: Download and install Windows Password Recovery Tool Professional.Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn aWindows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4: Remove the forgotten Windows password with the burned CD/DVD/USB. Then log on to Windows without a password.
As the above method, you can finishwindows password remover, I think it is helpfull for you.
http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 18, 2012 | Dell Inspiron Mini 10v Netbook Computer
How to do system restore on asus laptop
Go to your start menu and in the search field type in system restore. Click the program and follow the on screen instructions.
May 12, 2011 | ASUS Computers & Internet
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Hello, It seems I have to re format my HP 1000 Mini. It will not start in Safe or any other mode from the advaced options menu. It just goes to a blank screen when you do select anything on the advanced...
You cannot use another laptop as an external drive.
I would not try a re-install just yet though. The bios will try to boot from your selected device and a failure to boot usually gives an error message of some sort. I would first try to get a boot CD/DVD that will let you boot up and check the hard drive for errors. If you have a bootable windows CD/DVD this may allow you to carry out diagnostics before you resort to full re-install.
Feb 20, 2011 | HP Mini 1000 Netbook
I have a mini notebook and would like to install office 2007. I cannot install using a cd rom since there isn't one. is there another way I can do this?
Install it from a hard drive... or.. set your pc on a network then share the cd room on the other pc ot he network... run and install the application...
Dec 30, 2010 | Microsoft Office Professional 2007 Full...
Dell Latitude D800-Win XP- My Dvd/rw wont write
Because you lost two devices, the DVD and the wireless mini card, I believe your problem is a drivers issue.
You should make sure you do not have any Malware that is removing these drivers.
If you have access to the Internet download and install Malwarebytes. It has a quick scan that will ID any infections.
Then get the newest drivers for those two devices from Dell's support site.
Before you install the drivers, remove those devices in Control Panel.
Mar 20, 2010 | Dell Latitude D800 Notebook
Installing windows xp
You will have to purchase an external dvd rom drive. Then select the external to boot from in system bios. You can copy win cd to usb stick and install from that but it is a little tricky. Good Luck.
Nov 23, 2009 | HP Mini 1000 Netbook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
