Question about Home
Water continues to drip from fill tube after the fill.
It drips or even runs slowly.  If I turn off water supply it continues to drip for minutes and then stops. The amount of water in bowl diminishes when I turn off the water. Why? If the water supply remains on, the toilet makes a sound as though it is topping off the fill every so often. Also how do I adjust the water level in the tank. I see the device but do not know how to work it to lower the level which is very near the top of the overflow tube.Thank you!
  • 334 Answers
Chances are the flapper is leaking. Thats causing the random refilling as the tank slowly loses water into the bowl.
Replace the flapper with only the best available at your supply house. the cheap ones tend to leak even when new. The good ones are less than 8 bucks most places.
If your fill valve has the float ball, there should be a screw right on top of the fill valve at the end of the rod holding the ball to adjust the water level.
Closckwise lowers the level.
Be carefull not to break the plastic ones. If the adjustment is all the way in or does not work, you will need to replace the fill valve.
You could also try bending the metal rod holding the ball, but only as a last resort.
Posted on Dec 04, 2008
  • thanks Danny. adjusting the screw worked as you suggested.
I had same issue but with different solution... I noticed that the rubber fill tube was rubbing against the inside of the flapper assembly just enough to prevent flapper from fully sealing after flushing. I routed the rubber fill tube so that it doesn't touch or impede the flapper valve.
Posted on May 20, 2009
Ice machine fill tube keeps dripping
What is the model number?
Oct 28, 2012 | Refrigerators
Water leaking from icemaker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2011 | Kenmore Refrigerators
I have a GE PFS22MISBBB. On the back exterior of the appliance the waterline to the icemaker pushed itself out of its connector and leaked water on the floor. I shut the water off and inserted it back into...
Sounds like ice blockage or other foreign material is built up inside of of fill tube. Try removing hose and visually inspect fill tube. Sometimes a slow drip will freeze tube shut. Replace fill valve if it continues to drip and freeze.
Sep 18, 2017 | GE PFS22MIS
Maytag model MZD2766GEW. The water tube supplying
Jun 28, 2011 | Maytag MZD2667HE Side by Side Refrigerator
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
The icemaker is dripping when filling up with water, causing a giant frozen ice on right side. its level and don't over fill. lost manual so cant trouble shoot. so, was someone with this problem or had...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube and divert the water into the ice bin. You can take the water line off the valve and watch to see if it drips.
Jan 28, 2011 | Refrigerators
Water from ice maker running through freezer and on to floor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and divert the water. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Dec 03, 2009 | Amana Refrigerators
Ice maker leaking inside freezer compartment, water dripping down from unit
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Home Logo
1,034 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
