Question about Toshiba Satellite A100-S8111TD Notebook
Sound output is very low
Tere is lot of additional noise on increasing the sound
  • Anonymous Dec 13, 2008
    Sound output on my satelitte pro is terrible
Sound card driver
Posted on Nov 30, 2008
Replace lifters
First how many miles on the vehicle and how long was the car run low on oil? Most cars today have an integrated fuel pump that will shut off if the engine is low on oil. Most likely you have either gotten some dirt into the lifters causing the noise so I would start with a fresh oil change and filter and add a good oil additive to help clean the insides of the engine. I personally like Rislone products because I have had good luck with them but any good additive that quiets lifters will have a detergent to help clean the lifter and help prevent lifter bleed-down.
Aug 22, 2014 | Chevrolet Cobalt Cars & Trucks
Screaming noise at high speeds
Sounds like wheel bearings. There just isn't a lot on that bike that increases with speed, it's either wheels or engine. If it's engine- it will make noise in neutral. If it's wheels, it will only make noise while actually moving.
Mar 01, 2013 | 1999 Honda GL 1500 SE Gold Wing
My 98 mustang cobra was being stored and occasionally driven by my daughter. It started clattering at1800 rpm. When she checked the oil it was 3.5 qts low. There is no evidence of it burning oil or of a...
Thatt's an awful lot of oil. Hopefully it might be just some lifter noise. You might try an additive to clean the oil. I would also think of doing a complete service and check up on the Mustang.
Mar 20, 2011 | 1998 Ford Mustang
My pc's Front fan is giving bad sound and its speed increases while playing game and give sound but at normal using like chating playing songs it works oK now what to do any one plzz
When you are playing a game, your CPU has to work a lot and a lot of heat is released. To cool it down, the fans run at a high speed making that bad sound. Playing a song does not require a lot of CPU work. To reduce this get a additional fan which can control heat without making noise. Make sure your CPU and the Heat sinkers present are free of dust.
Dec 28, 2010 | Dell OptiPlex GX620 PC Desktop
Loud clink/clanking noise starts only after 1998 Wrangler warms up after long idling and then quiets when placed in park, while setting in driveway. After vehicle sets and cools it is fine. Runs and...
Your oil is thinning out too much. Lucas oil additive would be a great thing for this or an oil change with a little heavier weight oil The other cause of this could be piston slap from low grade fuels.
Sep 03, 2010 | 1998 Jeep Wrangler
Oil in 2000 lincoln ls is 4 quarts low after only 3 months, now there is knocking in engine.
Hi!!
This noise can mean bad news, but, let's not panic and try something.
Some times when oil level gets too low, the lifters discharge and valves start making a quick knocking noise that doesn't quit even if the oil level is normal.
and increases when you step on the gas.
This happened to my friend's car and fix the problem adding a Valve Quiet oil additive, in a couple of minutes the noise was gone.
If this is not the noise you are hearing, take it to a mechanic shop for repair, preferably on a Tow Truck, because the more you run the engine, the more damage you can cause to it.
Good Luck
Mar 12, 2010 | 2000 Lincoln LS
Car amplifire when conected to nokia mobile music player and when sound level increases of the mobile device the output sound cuts and plys also plys very low sound
Mobile r not good for playing music in a heavy system because Mobile has not a good sound quality as iPOD and others players have, also all mobile has not a capacity to play with amplifier, and the sound output of your mobile is low there fore u r getting low sound. If your amplifier has its own volume control then u can increase it from there. It is best to use iPOD. Thanks
Nov 25, 2009 | Sony XM-222 Car Audio Amplifier
Sound output
This comes under business class range.Note books in this range will be low in sound and multimedia
Nov 01, 2008 | Computers & Internet
Incoming call sound
that not possible becouse 6600 have monophonic speaker so output not increase or u can use .wav files to get increased volume.
Jul 11, 2008 | Nokia 6600
"cracking" noise
Your subwoofer is not capable of playing as loud as you want it to. That sound is the woofer reaching its limit. If you have any bass tone setting on your receiver set them to flat. If there are any other bass settings i.e contour, loudness boost etc turn them off. You can also try putting the woofer into a corner. This will increase the output. Closer to you would also be louder. Otherwise you need a sub with more output. Don't let the power rating fool you when you get a new one.
Aug 26, 2007 | Acoustic Research ARS108 Speaker
Toshiba Satellite A100-S8111TD Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
