Question about Teac FD-05PUB External Floppy Drive
Teac usb portable diskette/got cd but useing windows vista
I just got the Teach portable diskette but useing windows vista but some of the pics dont seem to come out when useing this diskette divace. do i need to install the driver for this ??
    Problem Solver:
  • 7 Answers
Try this solution.
http://www.fixya.com/support/t357073-need_vista_driver_fd_05pub_teac_usb
Posted on Dec 01, 2008
Usb portable diskette drive driver
Usually their is a hole in the front to insert a straightened paper clip. Push the clip deep, it will connect , and the door will open.
Dec 05, 2013 | Teac Computers & Internet
Imation link troubleshooting
Connect it. Any "plug-and-play" device with a USB interface should be supported by Windows XP/Vista/7/8.
May 14, 2013 | IBM USB Portable Diskette Drive (05K9276)...
NEED"S DRAIVER FOR IBM USB Portable Diskette Drive
Any "plug-and-play" device with a USB interface should be supported by Windows XP/Vista/7/8. Try it!
Feb 21, 2013 | IBM USB Portable Diskette Drive (05K9276)...
Free download of Drive Portable Diskette Drive-N533 for Window 7
May 05, 2012 | IBM USB Portable Diskette Drive (05K9276)...
Just bought a teac fd-05pub usb portable diskette drive. i have a dell computer with windows vista. when i pluged it in the device was installed, however the power light comes on for a few seconds then...
The below is on the basis that the drive is visible in "Computer"...
This can be tow thing, one the drive is not receiving enough power from your USB port, try unplugging any addtional USB devices connected to the PC, if this doesn't work try a powered USB hub. Second the floppy disk is faulty or the drive itself is faulty.
Hope this helps, let me know how it goes.
Thanks
Jul 11, 2011 | Teac FD-05PUB External Floppy Drive
I have a Teac USB portable diskette drive, N533. Until recently, it has worked okay. However, it has started not opening any diskette I put in and instead a message appears that the disk needs to be...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Apr 28, 2011 | Teac IBM USB Portable Diskette Floppy...
Dears, I cannot install Windows XP to my Aspire 5710Z, System cannot detect by HDD. In Bios is HDD visible, instaling Windows Vista by Acer CD Anytime upgrade works. Many years ago we was using...
Hi Tom!
You DO need the SATA drivers diskette! Download it from here.
The easiest way will be using a USB Diskette Drive... Follow the instruction in the included README file (section "5.3 Pre-Installation Using the F6 Method") to complete your Windows XP installation!
If you can't find any USB Diskette Drive - it's a little more complicated... Follow the instructions here!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck and best regards,
Pelu.
Jan 04, 2011 | Computers & Internet
Need for IBM USB Portable Diskette Driver for windows 7
Nov 12, 2010 | IBM USB Portable Diskette Drive (05K9276)...
Have bought a second hand IBM USB Portable Diskette Drive. It worked just fine at the sellers place. Now that I try and use my own PC I load a 1.44 Mb diskette and it tells me to load disk ??? What to do...
Hi Graham,
Your Portable USB 3.5 diskette drive uses a pretty old technology that would come with software or drivers needed to run it. You would need to check on your device manager on control panel. But I would advise you upgrade yourself to better storage devices like the flash drive or the CD/DVD USB portable drives. They are a bit more expensive, but the technology is newer and have less issues. Let's face it, the 3.5 diskettes are getting pretty outdated. Don't you think so?
Cheers & Kind Regards
Sep 24, 2009 | IBM USB Portable Diskette Drive (05K9276)...
Need vista driver for FD-05PUB teac usb floppy drive
You should have (if bought new) had a mini disc in with the drive. If not try the manufacturers site and download it. It's also possible by doing the add/remove hardware and pointing towards Microsoft for the driver it will install for you. Hope this helps...Tango.
Jan 17, 2008 | Teac FD-05PUB External Floppy Drive
Teac FD-05PUB External Floppy Drive Logo
863 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
