Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
I have a Bissell Powersteamer & it won't throw out the water.
The trigger button doesn't seem to work.
  • SandrDye51 Nov 28, 2008
    How do I order a new handle?
    Scholar:
  • 55 Answers
You can test the trigger to see if that is the problem. Take the two handle bolts out, gently pull back on the tool rack and slide the handle up off the unit. If you look down inside of the unit where the handle was you can see the valve that the handle used to actuate. You can turn on the unit and manually activate the valve with a long screwdriver. If it starts working then you know it was the upper handle.
Does it spray out the tools? If it does then you have a clogged heater. It is located in the lower handle and can be taken apart and cleaned out.
Good Luck
Posted on Nov 25, 2008
Bissell 16971 has a leaking problem when turned on. The water flows out too fast. Any recommendations as to what is may be?
it is possible that the auto load assembly is damaged or your trigger (button) is stuck. Also check to be sure nothing is stuck in your auto load assembly (this is the part with the spring that allows the water to flow only when pushed up on).
check section on which the auto load would rest to make sure it is also moving freely when trigger on handle is depressed, and not stuck in the up position.
I included link to ereplacementparts.com they have tare down pics and all the parts if new are needed. I have used them for parts to my side by side a few times. good luck
Bissell 1697 Upright Proheat Powersteamer Deep Cleaner Parts
Apr 18, 2015 | Bissell Vacuums
My Bissell PowerSteamer 1697 series won't discharge water. At first it was just the vacuum art now its also the handtool.
You may have problems with your pump belt, gaskets, or tank. Use this link to determine the exact tip to fix your unit: http://www.bissell.com/FAQDetail.aspx?id=1065
If these don't help, please take your unit to a service center for diagnosis and repair. You can visit a BISSELL Authorized Service Center by locating one here: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50
Sep 30, 2012 | Vacuums
Will not let any water out when i squeeze the water trigger.
Try squeezing the trigger a few times repeatdly. This usually works for me.
Mar 21, 2010 | Bissell Powersteamer 1694 Upright Vacuum
could be a few things.. take the lid off the tank and try spray.
did you fill the bladder and not the outer tank.. rubber on bottom of tank still there.. releases fluid it you depress the x shape center..
hot water. prime from hose without a tool on it by holding the hose lower than the tank.. put in on a work bench.. hold spray trigger and turn on machine.... read my other posts as well
Oct 23, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Water leaks where the hose connects to the trigger handle.
Be sure to get a good washer on with the connection. They're easy to buy at any hardware store. You can also put white plumbing tape around the threads before screwing them in to make it really fit.
Sep 28, 2008 | Bissell 1631 PowerSteamer ProHeat Canister...
Not putting out water
I had the same problem with mine and it was an easy fix. If you remove the soap holder without putting the selector dial to "water only" you will lose the prime in the hose that goes to the water chamber. It takes a few minutes of pulling the water trigger to regain that prime, but it will come back eventually. Easiest fix, of course, is to always remember to dial to water only when you need to add cleaning solution..
beth
Jun 02, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell powersteamer
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=523747
Posted by bzthe boss on Apr 18, 2008
I can’t get it to work correctly, how do you work this thing??
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Most of the Bissell 1698 Power Steamer ProHeat Upright have a water holding tank and a dirty water recovery and a trigger assm to release the water and the scrubbing brushes underneath that do the scrubbing and some of the scrubbers heat the water so that it is hot when it goes down to promote better cleaning, other than that you should check the owners manual for the steps on how to use or contact the cust service dept @ Bissell and have them walk you through the steps that I have listed below: So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 18, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 PowerSteamer ProHeat Upright will not work. The brushes spin, the soap comes out, but no water is getting to the carpet.
You may try the trigger assembly may not be releasing the water , your brushes spin and the soap comes out but no water – it may have come unhooked or broken, also the water line could be plugged, clogged or pinched and not releasing water to the brushes -- you may try the owners manual for the trouble shooting for the item or check the Bissell website listed below or the customer service phone number of 1-800-237-7691 – the website has a list of trouble shooting listed right on the website I you enter the Model number and hit trouble shooting
By Phone Customer Service:
(800) 237-7691
Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Apr 15, 2008 | Vacuums
Bissell 1697w Powersteamer
I have a similar model and occasionally have problems with water/detergent flow. I find it is generally due to an airlock in the piping caused by forgetting to turn the deregent water control off before removing the detergent container. Follow the manual instructions. Turn the knob to off. Fill both containers. locate them carefully. Make sure filters in the water tank and in the flow meter are clear. Start machine with handle laid flat and knob turned to maximum flow.
Dec 22, 2006 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
136 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
