Question about Zyxel G-405 (91-005-070002) Wireless Adapter
I need a default ip address for zyxel G-405 wireless lan ethernet adapter
  • 64 Answers
The Ethenet parameters for the Zyxel-G405 are preset from the factory. The default values are:
IP Address 192.168.1.11
Subnet Mask 255.255.255.0
A link to a user guide is located at: ftp://ftp.zyxeltech.de/ZyAIR_G-405/document/ZyAIR_G-405_v1_UsersGuide.pdf
Posted on Nov 25, 2008
I have a toshiba satellite laptop my router is a zyxel p660hw the laptop can connect wirelessly to the router and gets full network access but no internet connectivity i work in an office and there are...
what is the laptop's ip address when on wireless ? default gateway ? subnet mask ? when connected on wireless ?
what are these when connected to cat5 ethernet cable ?
Is the default gateway different ?
is the ip address within the network address ? 10.0.0.3 to 10.0.0.254 or 192.168.1.3 to 192.168.1.254 ?
the first three digits should the same
what is the wireless ip address is it the same as the network router or different ?
What is the dhcp leases are they conflicting with the main router and wi fi router ?
How many DHCP servers are there ?
Nov 16, 2017 | Zyxel Prestige 660HW Wireless Router...
I cannot access all websites with my wireless-n home router. what should i do orwhat could be the problem?
Make sure the physical connection is good between the computer in question and the D-Link gateway. If you do not have a solid link light, try swapping cables. Make sure the ethernet adapter is installed and functioning properly.
If you are running any firewall software on the computer that cannot connect, disable it. Make sure the TCP/IP settings are set to obtain an IP address automatically. Try releasing and renewing the IP address for your ethernet adapter. It should pull a 192.168.0.x address with a subnet mask of 255.255.255.0 and a default gateway of 192.168.0.1. If it does not get an IP address in this range, specify the address to be 192.168.0.10, subnet mask 255.255.255.0, and add the default gateway and primary DNS 192.168.0.1. Try and go online.
If it still cannot get online, go to the Control Panel and open Internet Options. Restore the default settings on the Security and Advanced tabs. On the Configuration tab, make sure the Dial Up setting is set to never dial a connection. Click the LAN settings button. All you want selected here is automatically detect settings, uncheck the other two boxes. Try and go online.
Nov 13, 2010 | Linksys Wireless-N WRT150N Router
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
I have a zyxel router, after connecting to the laptop via wireless, sometime it cant load the webpage such as www.google.com. but the wireless signal there showing "Connected" with full tab. After once...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Zyxel ZyAIR B-100 802.11b (AM5009004)...
No connection via Ethernet between Zyxel P-660HW-D1 and PC
Hi Friend,
Before Connecting your internet we must check in ur system.
1.Go to Start---->Run------>type cmd----->in the black screen type ping 127.0.0.1
2.check wither its getting reply or request
3.If u are getting reply then ur system is perfect i.e., your NIC Card is installed properly.
4.check wither any proxy is enabled in the LAN settings.
go to browser--->tools---->internet options(Options)----->Connection--->Lan Setting--->there should noy be any tick mark in the boxes
Now we can check the connectivity,
1.Connect the PC from the Router Lan Port and the modem connectivity to the Wan Port of the Router.
2.Assign the Ip address as obtain ip address automatically
Right click networkplaces--->properties--->Lan Connection Properties---->double click the internet protocol(Tcp/IP).In the next box u must select the Obtain Ip address automatically
3.Now u switch on the modem after 30 sec switch on the Router.
4. Launch your web browser.
5 Type "192.168.1.1" as the URL.
6For administrator access enter the default admin password 1234 to configure the wizards
and the advanced features.
7 Click Login to proceed to a screen asking you to change your password or click Cancel
to revert to the default password.
8 If you entered the admin password, it is highly recommended you change the default
admin password! Enter a new password between 1 and 30 characters, retype it to
9.Then u can configure the ip address
Regards,
Ayyasam
May 29, 2009 | Zyxel P660HW-D1 Router
Re set wireless usb adapter
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  3. Click Wireless Settings under Setup menu.
    1. Under Security Options, Select WEP (Wired Equivalent Privacy)
    2. Change the option to Disable
May 18, 2009 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
Zyxel G-405 (91-005-070002) Wireless Adapter Logo
248 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
