Question about Baumatic BTWM4 Front Load Washer
Baumatic washing m/c btwm4
Wont final spin with clothes in ,take them out and it final spins??any ideas,brushes seem ok,is there some kind of weight sensor?wifes says load no bigger than normal,or is there a float switch saying too much water in to spin???help!!!
Check that the drain filter is clear, if thats ok its probably going to be the electronic module at fault.
Posted on Dec 02, 2008
Our new integrated washing machine (Baumatic btwm4) sometimes doesn't spin properly and clothes are very wet. Even thought a single spin is selected, the same poor result. The machine is definitel
1) tes the belt for broken or worn replace
2)test the door switch, this cause to NOT spindle the machine , replace if necessary or readjust
3)Main control module or CCU, if the door switch test o.k, tight any wires connector well from loose, otherwise the CCU is faulty.
4) motor control module, this receive signal from CCU, tight any wires connector for loose, otherwise you must replace the board faulty.
Jul 18, 2012 | Washing Machines
Water not draining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2010 | Baumatic BTWM4 Front Load Washer
I am having issues with my washing machine. At it's final spin it seems to be off balance and makes loud noises
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 05, 2010 | Frigidaire Washing Machines
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
Bosch washing machine wont distribute clothes properly before going into spin
1st any washing m/c distribute clothes properly by reach to final spin speed gradually not abrubt so if your drum reach this speed suddenly so it will not distribute clothes properly >
2nd you need to but clothes one by one and must be correct weight not exceed>
so it is clear now i think
thankyou
Jul 09, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Spin cycle
Without any other info. this sounds like the basket drive is worn out. Depending on the brand, it has different names, but it all does the same thing. Its kind of like the clutch in your car. It has to slowly get to speed. Yours, without any clothes in it has no load. But when you add weight, it doesn't have enough power to turn it. Its slipping or just worn out. Just wondering, why did you change the water pump? Did the wheel on it break?
Mar 07, 2008 | Washing Machines
Baumatic btwm4 washing machine wont rinse and empty
If it wont empty its either a blocked pump/or filter. If it won't move on, heating element
Jul 11, 2007 | Baumatic BTWM4 Front Load Washer
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Baumatic BTWM4 Front Load Washer Logo
237 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Marvin
Marvin
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
