I need to know how to disable the onboard card to run a GeForce GTX 550 ti video card on it.
1. Start your computer and Hit the <Del> Key (Delete Key) several times
until the Bios screen comes up.
2. Select the "Advanced" Tab
3. Select "Chipset"
4. Select "Primary Display Adapter"
5. Change the value to "PCI-E"
6. Now exit out of the Bios Saving the changes by using the <Esc> and
F10 Keys.
7. Congratulations you did it... Reboot your computer.
SOURCE: Hi, I've got the asus p5n-em hdmi motherboard but
If it won't see any moniter then it's turned off in BIOs or it's dead. which means you will have to go to BIOS and turn on the built in video adapter by pressing DEL when booting up and going into BIOS and settings and turn on built in VGA Video or buy a new AGP or PCI 2.0 Grafics card and turn off the on board video.
SOURCE: Will ASUS motherboard P5N-E SLI power up without a
No, it needs a video card, of any kind, with a monitor attached to power up.
SOURCE: I want to upgrade to
Hi bain_j,
your motherboard has a slot for this. I have encircled the slot on the picture I have attached. Also I checked and the current Power Supply that came in with your HP Pavilion will not be able to support the card. You would need to get a new power supply unit preferably around 600 watts and with a PCIE 6-pin power. I hope this helps. Please let me know.
Janc30
Janc30
SOURCE: I have an Asus M2N68AM-Plus Mobo and a Asus
your motherboard is not a 64-bit board so it cannot support the windows 7 64-bit version. you should get the 32-bit version or upgrade your ram and then your windows should be able to read your onboard video.
SOURCE: can we run gtx 550
Yes, it will run just fine, only that the video card is way more powerful than the board so it will be slowed down - you won't see any difference compared to a weaker card.
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630939.html
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don't use numbers and / - you might have to try a few times to get it right
also the download software finder under that there will be a list place a tick in the box of any one you want/need
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or you might need to download one
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630932.htmlI Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630939.html Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs.What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature hope this helps
hope this helps you
insert the card into the pci slot on you motherboard turn your computer on the found new hardware should activate and ask you to install the drivers/software for it
if you need more help with this post a reply
hope this helps you
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUsIncreases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature
