Question about Acer TravelMate 525TE Notebook
I have a problem in my key board
When i type one character in appears 3 to five character ,, what will i do
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Does this happen with all keys pressed?
  • 34 Answers
Hello
Ur keyboard has went bad just go ahead and replace the keyboard.
Thankyou
Posted on Nov 26, 2008
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Tip
    Short cut keys for Blackberry phone,storm,curve,pearl.bold
    Typing shortcuts keys for BlackBerry
    These shortcuts keys can be used when typing text in Blackberry:
    • If you want to type the alternate character on a key, hold the Alt key and press the character key.
    • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
    • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
    • To insert a period (.), press the Space key twice. The next letter is capitalized.
    • To capitalize a letter, hold the letter key until the capitalized letter appears.
    • To turn NUM lock on, hold the Shift key and press the Alt key.
    • To turn NUM lock off, press the Alt key.
    • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
    • To type a number in a number field, press a number key. You do not need to press the Alt key.
    • In order to type a number in a password field, hold the Alt key and press the number key.
    • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
    • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
    Know more about Windows 7
    Windows 7 keyboard Shortcuts
    on Dec 05, 2009 | Cell Phones
    Tip
    How to use Blackberry as a modem to acces internet?
    Dear Sir , If you start copying a Class 10 / 11
    I understand the pain and how difficult it is to work on a science document!!!!!!!!!!!!
    By the way if you are using the office suite applications such as Word 2007 or word 2010, you can insert the symbols easily.
    To insert a symbol or special character into your document, follow these steps in Word 2007:
    1. Position the cursor where you would like to insert the symbol or character
    2. Open the Insert ribbon
    3. Click Symbol in the Symbol section
    4. A menu will appear with a small selection of symbols
    5. If you don't see the symbol or character you'd like to insert, click More Symbols
    6. Use the controls to select between symbols and special characters. Additional tools on the symbols tab will help you expand or narrow your selection
    7. When you find your symbol or special character, click it and then click Insert
    8. When you're done, click Close
    The symbol or special character will appear at the appropriate place in your document.
    Hope this helps!!!
    Well, I am helpless regarding developing a keyboard with all those scientific symbols,.LOL
    W
    Jan 07, 2011 | Logitech 967437-0403 Keyboard
    Are trying to enter the WEP key and it is not allowing any more the 5 characters (please input 64 bit WEP encryption and Five ASCII Characters))
    It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption.
    Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead.
    Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
    Click here if you cannot access the web-based configuration.
    Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
    Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key.
    Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption.
  • 64-bit encryption 10 characters
  • 128-bit encryption 26 characters
  • 256-bit encryption 58 characters (available on DI-614+ only)
    The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key).
    Step 5 Click on the Apply button then click on the Continue button to save your settings.
  • Jun 25, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Fn key active
    This is not because Fn key its Num Lock key that changes jkl to 123. Just turn Num Lock button off.
    Apr 09, 2009 | Acer Aspire 4520-5141 Notebook
    IBM Wheelwriter 3 typing incorrect characters
    If you have another printwheel try that, if you still have the trouble try blowing out the area where it is in stalled. If that fails turn the machine off then back on, after it completes the POR mark the printwheel with some white out, repeat the POR see if the mark is in the same place, if it isin't you probably have a selection plate problem.
    DickyO
    Nov 11, 2008 | Lexmark Wheelwriter 3 Typewriter
    Toshiba tecra s2 keyboard starts skipping typed characters and stalling
    there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
    pls remove the key board cap carefully and clean
    Apr 29, 2017 | Toshiba Tecra S2 Notebook
    Keyboard Problem
    To activate StickyKeys
    1.
    Press the Shift key five times. A dialog box opens with instructions on how to set up the StickyKeys feature.
    2.
    If you click OK, an icon (a group of squares) appears in the notification area.
    To turn off StickyKeys, press the Shift key five times.
    Hope this helps you......
    George
    Mar 30, 2008 | Compaq Keyboard
    Acer TravelMate 525TE Notebook Logo
    83 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
