Question about Dryers
Ihave a maytag electric dryer model #MDE308DAYW
The puuley broke and the dryer wont spin, does anyone have instructions on how to replace pulley and belt on this model ?
  • Anonymous Mar 20, 2014
    replace door switch
    Sergeant:
    Champion:
  • 291 Answers
Make sure it is unpluged ,,,,, take the two screws out on bottom of front panel, pull out and drop down, remove 2 screws holding top down and raise, 4 5 1/16 screws holds front cover in place, take those out, left up and remove ,,,, you can see all from there ,,,,,, drum also has to come out to replace parts.
Posted on Nov 25, 2008
Please in very careful detail exsplain how to attach four prong plug wires to my maytag model no mde308dayw please help?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2011 | Maytag MDE308DAYW Electric Dryer
I have a maytag dryer model # mde308dayw. How do you access the heating element to replace it?
remove 2 screws on the front cover by the floor lift bottom of front cover outward toward you and remove ,then undo wires at door switch,then remove drum belt and drum,then the heater element is at the right side near the base in a duct assembly
May 04, 2011 | Maytag MDE308DAYW Electric Dryer
When i turn on the dry it is making a loud Squeaky sound. the dry is still heating, just making loud squeaky sound
Hi an welcome to FixYa, I am Kelly.
This squeaky sound your hearing is usually the idler pulley, idler pulley shaft, but also can be the motor or the drum roller bearings. Usually if the drum roller bearings are bad the dryer will thump as it rotates.
The idler pulley and lever is and assembly that is item 8 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598568#d28598568
Since it is squealing at this time when you have the repairs done that you replace the belt that is item 21 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572
The motor is item 7 this link:
I recommend that if you do the repairs that you replace the idler pulley, the drum rollers, and the belt.
Drum rollers are item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572 (make sure to check the drum roller shafts that are item 19 of the same link.)
While repairs are being completed also inspect the drum front and rear seals. Thare are items 14 and 26 (Same part number) of the above link.
By doing all of the above you should be able to get many more years of service out of your dryer.
If you need to purchase a service manual for self repair it can be downloaded here for $9.95:
http://allrepairmanuals.com/maytag-dryer.htm?model_number=MDE308DAYW
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Maytag MDE308DAYW Electric Dryer
When I turn on the dryer it squeeks very loud for a minute or two. What should I replace to fix the problem???
WELL YOUR GONNA HAVE TO CHECK THREE THINGS REMOVE FRONT CLIP AND TUB SUPPORT 2 REAR ROLLERS SPIN FREELY OR IDLER PULLEY ,BLOWER WHEEL
Jan 25, 2011 | Maytag MDE308DAYW Electric Dryer
My Maytag model MDE308DAYW squeaks and grinds when turned on.
i would assume that either the rear roller(located directly atop your heater, or yout idler pulley has gone bad , parts are probly about $40.. not a bad repair, you can probly find a how to on you tube
Oct 09, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer motor wont start
maytag dryer m#mde308dayw will not start just hums
Jun 03, 2010 | Maytag Neptune MDE6700A Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
My Maytag MDE308DAYW needs a new belt. Belt was
If you go from the top. The belt goes down the drum, between the drum and idler pulloy,under the idler then pull it over to the top of the motor pully and loop over it. When it comes out from under the motor pully it goes under the drum and over to the other side of the drum, and back up to the top of the drum. I hope this makes since.
Please rate solution if helpful
Aug 28, 2009 | Maytag MDE308DAYW Electric Dryer
Dryers Logo
150 people viewed this question
Top Dryers Experts
