Question about Jacuzzi Pool & Spa
Scheduled maintenance I have a Jacuzzi Cyget pool pump. is there any scheduled maintenance I need to accomplish on the motor or other parts other than cleaning out the debri?
    Problem Solver:
  • 11 Answers
Jacuzzi pumps are very reliable. If you keep the debris out of it, you should be fine. It will let you know when it needs help... a squealing bearing immediately comes to mind.
Posted on Jan 03, 2009
A lot of pressure from pump
if you pump is pumping too much water then you can use a gate valve on the discharge side to reduce the water flow.
Rod
US Parts Center
888-521-6183
Jun 03, 2012 | Jacuzzi Cyget In Ground Pool Pumps
My jaccuzi message pump pressure is low
It could be any one of the following problems. Try these troubleshooting steps for Jaccuzi pool pumps.
1)Pump not primed. Prime pump.
2) Leakage of air into suction system
3)Impeller clogged
4) Valve in suction or discharge line partly closed; Suction or discharge
line partly plugged or too small.
5)Plugged basket in skimmer or hair in lint strainer.
6)Dirty filter.
Aug 05, 2010 | Jacuzzi Cyget In Ground Pool Pumps
I Have a Jacuzzi Magnetak pump. I do not know the horse power. 115 volt, 12.4 amps, 3450 rpm. It is attached to a DE filter sstem. The pump is at least 6 years old. It runs well and pumps well for 1-3...
The earth filter is in need of a good cleaning. You may even need to acid wash it. Welcome to the high-maintenance draw-backs of a DE filter! Once cleared your system should go back to operating normally.
Jul 30, 2010 | Jacuzzi Cyget In Ground Pool Pumps
I have a jacuzzi magnum force pump I am trying to plumb the pvc into the pump I lost the screw down union what size do I need to buy and where do I buy a union to fit this pump
Go to your local pool supply get a union to match the sise of your pipe ... or ... just glue it together today and add the uniion next time you have to take that part out.
Jun 05, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Jacuzzi is hot heating
TIME TO BUY A NEW COMPLETE PUMP !! I RECOMMEND A STA-RITE DURA GLASS PARTS FOR THE JACUZZI ARE HARD TO FIND AND $$$ SCRAP IT REMEMBER TO PRIME YOUR NEW PUMP ... THUMBS UP IF I WAS OF HELP.. THANKS JAY.. THE POOL PUMP REPAIR GUY
Apr 03, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Anyone know were i can find technical drawings for a jacuzzi signa whirlpool tub. there are two water hoses that don't seem to go anywere.
If they go down they are probally for draining and if they go up they are probally hooked to an ozone unit and just pull little amounts of air in.
Jan 21, 2010 | Jacuzzi Cyget In Ground Pool Pumps
I have a Jacuzzi laser sand filter. The system worked fine until I noticed that the circulating motor was extremely hot when running. The pump and motor were very old and in poor shape. So I replaced the...
this sounds like a supply power problem. The motor is not getting enough power. Check the line to see how many amps you're getting. The motor will tell you how many amps you need on the data plate. When a motor heats up and trips it's internal high limit, it's usually due to insufficient supply power. Heat is a byproduct of inefficiency. Also, if this is running on 220v, make sure both legs of 110 have power. Sometimes motors can attempt to run even though half the volts are missing.
Oct 30, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Air in my jacuzzi pool pump
It sounds like air is entering the system through the clear dome (filter access) on the pump. Check the o-ring directly underneath the clear plastic dome. CAUTION: Be sure to isolate the pool from the pump via in-line shutoffs prior to loosening the dome lid. Sometime cleaning the o-ring and coating it with petroleum jelly helps the unit seal better.
Aug 02, 2009 | Jacuzzi Cyget In Ground Pool Pumps
One out of 5 jacuzzi outlet works with force, the other do not even when the air flow is totally open.
try turning off the 5 previous jets in order to see if there is enough water flow to get to the last jet.
Feb 17, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Pool & Spa Logo
179 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
