Question about Canon MF8180C Color Laser MFC Printer
No copy quality in my ir400
Sir, I have Ir 400 machine. though i have changed the drum, increased the darkness by way of additional functions and copier->adjust to 20,
and i have the cleaned the machine, i can not improve the quality of copies. sometimes it may affect the goodwill of my concern. What shall i do sir?
    Sniper:
  • 54 Answers
To improove copy quality
1: clan the cd unit & use fresh toner
2: clean the primary & transfer charging rollors
Posted on Jan 21, 2009
SIR,i AM RUNNING IR 400 FOR 2 YEARS THIS TIME ONLY wHEN I CHANGE A DRUM THE PRINT WILL BE GOOD WHEN 200 COPIES CONTINUOUSLY TAKING THE DRUM DAMAGED IT MEANS SMALL CRACK ON THE DRUM AT THE FRONT DOOR SIDE...
first, did you install complete Canon original drum unit or just replaced with not genuine low quality drum?
Maybe the problem is in bad quality of drum.
In original drum unit you get whole unit with new drum, blade and charge roller.
Second, you should inspect the developing cylinder, he is magnetic and in some cases something like paper clip or other metal dirt can stuck on it and cause breakage or damage of drum surface.
I recomend you to remove the toner unit, vacume it and check for foreign materials, also rotate the developing cylinder and look for damages or foreign materials.
Hope that something of this will help!
Aug 24, 2011 | Canon imageRUNNER 400S Copier
Copy is very light. Cannot open the MENU & hence cannot adjust the darkness of the Copy.
First off all to go to menu Press star (Additional function) - 28 together and again star Go to Function - Density and increase/ decrease the number. DE - DC- 24 Dev - 15 Off - 128 Den - 7-9 And again There may be a number of reasons for a light copy 1. Drum - change the drum if it is run above 10 - 20000 copies 2. Blade - changing the blade simultaneously to improve the copy quality
Thanking you.
Jul 02, 2011 | Canon imageRUNNER 400S Copier
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me....
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
Jan 06, 2011 | Canon imageRUNNER 400S Copier
IR 400 NO ERROR BUT PRINT FULL BLACK COPY with out print
how make copy more dark by using additional function in ir400
Oct 13, 2010 | Canon imageRUNNER 400S Copier
Sir, I am having IR400, the copy became white coloured font with very dark black background, so i replaced drum & blade and then copies became normal, but very light, then i increase the density from 5...
Why did you do ccd-adj before cleaning the optics?
in copiers front door must be sheet with numbers that are factory input, do the clear all, and then set the values from paper in service mode.
May 18, 2010 | Canon imageRUNNER 400S Copier
Canon IR 400
i have canon ir405 cpier it dispays error code E243 please help me sir
Jun 01, 2009 | Office Equipment & Supplies
Need more quality
First, put all the settings back the way you found them, There should be a label on the inside of the front door with the original specs. Then set the ip_ofst and pri to the specs on the front of the drum unit. Then run d-Gamma under function>DPC and then run thru the procedure in function>dens. If you still have troubles then dump out the toner out of the developer unit and start with fresh toner.
Nov 25, 2008 | Canon imageRUNNER 400S Copier
Canon MF8180C Color Laser MFC Printer Logo
185 people viewed this question
old marine
old marine
