Question about Brother DCP-340CW All-In-One InkJet Printer
Unable to clean for dcp 340-cw brother
Called customer support, told them printer wasn`t jammed and had reset. they told me to unplug and reconnect holding the menu button.
it came up with error 46, and told me i would need to get an engineer. can i fix this myself?
  • julie thomas Oct 01, 2013
    Hiyer Spider ray, i followed you instructions and got '55 OK' on my screen rater than maintenance 80. Any suggestions? I also tried continuing with your instructions and adding in 2783 but my screen just keep saying '55 OK'.
  • 687 Answers
Try placing a piece of Black Electricians tape over the stepped part of the cartridge make sure it covers the whole of the length this will fool the sensor into thinking that the ink is full. If you just cover a part of it on a near empty cartridge it will save not installed.
This check is done to make sure that the print head doesn't dry out but in my opinion these are set too high and you can waste about 8% of you total ink. If you do this before you install the cartridge you will be able to use all of the ink. Then just replace it with a new taped one...
When you have purged , cleaned the print heads, your Brother Printer about 6,450 times it will be unable to print anymore. This is because they recommend that the printer is serviced this will cost you up to £120 (not bad for a printer that costs £60 NOT!!!)
The simple way is to spend £25 and buy your own replacement pads if you are up to taking the printer apart, see service manual this is hard to get hold of as are these instructions !!!!
In the mean time you can RESET this purge count back to zero using the MAINTENANCE 80 menu, to continue using the printer for a while until you get the new pads. But it on a tray as if they are full they may start to leak onto your desk....
1 . Press (MENU) (MONO START) then (^) OR <the up arrow> four times, the Photo Capture and Red Exclamation Lights will then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4. Press the (MONO START) its a toggle until you see PURGE:6451 ( I guess this means you have cleaned the heads over 6,450 times their threshold level.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
You can also RESET using the <2783> If you press the wrong key you will see MACHINE ERROR 46 on the LCD.
Almost forget to EXIT the Maintenance mode enter 9 twice by using the up arrow & set key's to exit from maintenance mode in the same way as entering the 2783 code, or power down the printer.
Brothers own solution is here
LOL
P.S. Check me out on www.windowstipsclub.co.uk
Posted on Sep 23, 2009
    its worked now, A slightly different version, mAYBE THATS WHAT YOU MEAN BY TOGGLE-(KEEP PRESSING UNTIL YOU SEE IT) THANKS SO MUCH. X
  • Anonymous Mar 19, 2017
    I followed the instructions, and purged to 00000. Thank you very much!
    But now it says (or the equivilant in English): "Can not change"?
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured.
You need to pres Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
Oct 29, 2014 | Brother DCP-J125 Colour Inkjet...
Brother DCP-9010cn is showing Unable to print code 73
The error code 73 means that you have a paper jam or a paper sensor problem.
here are a list of all the codes for brother printers:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000068/faq000168_005.html?reg=us&c=us&lang=en&prod=mfc5490cn_all
To troubleshoot paper jams go here:
http://www.manualslib.com/manual/355700/Brother-Mfc-9010cn.html?page=78#manual
If its not a paper jam you will need to call brother customer service as it may need a sensor part.
1-877-BROTHER (877-276-8437)
Mar 14, 2014 | Office Equipment & Supplies
How to reset brother DCP 165C unable to print
how can i reset my printer for brother dcp 165 printer..?
the erroe will appear in the computer is clean unable 5a...
Aug 18, 2010 | Brother DCP 165C Compact Color Inkjet...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Message comes as unable to clean ... cartridges are brand new no paper jam in the system the model is DCP 340 CW
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print head cable or circuit board.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 16, 2009 | Brother DCP-340CW All-In-One InkJet...
Brother Model DCP-340CW - Unable to clean
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Disconnect the machine from the power source for several minutes then reconnect it.
If the message continues to appear on the LCD, please contact Brother Customer Service.
hope this helps please leave rating (vote)
Jan 26, 2009 | Brother DCP-350C InkJet Printer
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Unable to clean problem
turn the rpitner of then check there is not any paper jam.
also refix crtridge after clean it.
Jan 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-340CW All-In-One InkJet Printer Logo
3,018 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
