Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
My keyboard is not working well
My laptop keyboard is not working fine if i should press letter (A) letter AZ will apear if i press letter (M) JM will apears I got same problem in my laptop... This is the starting stage guys... later on you cant use those keys with shift but the small letters will work fine and the shift keys will work fine with other characters...
Its definitely not a hardware issue... I had the same problem earlier, I reinstalled the OS... The problem got fixed... Now, again facing the same issue... I dont want to reinstall the OS and very curious to find out the cause...
May be we should find out whether we are using same kind of software or codecs... I doubt the Codec packs... It might have some bug...
How about you guys
    Genius:
  • 1,605 Answers
  • 837 Answers
Sounds more like your laptops keyboard needs to be replaced
Posted on Nov 25, 2008
This afternoon my laptop was working fine, then the keyboard started messing up, when I pressed any letter it came up with 4 other letters. Then i pressed '9' once and it continuously typed 9 until I
First thing I would ask is this. Was anything spilled on the key board? I had a situation similar to this and I found that my son spilled a Sprite and wiped it up but didn't tell me about it. One way to check this is to hook an aftermarket keyboard that runs off your USB2 port and see if the keys work correctly that way. If they do, I would suspect that something was spilled into your laptop keyboard.
Feb 06, 2013 | Computers & Internet
Juice spilled on dell laptop,the problem is when i press certain keys 3 or 4 letters apear,it is the same with a new keyboard
If that happens with a new keyboard then the mother board is faulty and a replacement laptop is on the horizon. What happens with an external (USB) keyboard?
Hope this helps.
Feb 03, 2011 | Dell Inspiron 1525 Laptop
When i type a letter A appers AZ, or letter s apears sxw ,all letters on 4th line on my keyboard when i click apears like that AZ SX DC FV G H JMU K, L.
first try a good cleaning with canned air then try it again if no improvement you might wanna try lifting your keyboard up and try to have the cable re-seated into the motherboard they can come ajar over time if none of those work it could be a keyboard failure new ones go for around 40-50$ new so try those tips you can also use an external in the mean time good luck
Nov 26, 2010 | Computers & Internet
When you type the letter u i o p j k l m number will apear instead of letter why?
Usually it's because the number lock is locked on.
Check your keyboard carefully for a key that reads "num lock" press it once and you should be good to go :)
p.s. If it's in blue sometimes you need to press FN + 'num lock"
Hope this helps!
Oct 14, 2010 | Dell Inspiron 4000 Notebook
I press certain letter keys and numbers appear, the number keys are fine just the letters, what is the fix for this error?
You have your numbers lock on, press the NumLk key and that should correct it. You will notice on you keyboard that there are small numbers on it below some of the letters, this is so you can use the keyboard has a 10 key number pad/ calculator etc. If pressing the NumLk key does not work, the key may be stuck or you have a bad keyboard
Oct 12, 2010 | Panasonic Toughbook CF-51 Notebook
My HP Pavillion keyboard is keying properly
az i think your keyboard language has changed. from language bar you should change the language of keyboard. control panel-region and language- keyboard and language- change keyboard.
Apr 06, 2010 | HP Pavilion dv7-1020us Notebook
I HAVE INSPIRON E1405. HOME KEYS ARE NOT WORKING
First boot to the Utility partition and run diagnostics on the keyboard (Fn Power button) see if they keys work correctly in the Dell Diagnostics keyboard test. If they do not, then either the keyboard or the motherboard is bad and I'd replace the keyboard first.
If the keyboard functions normally in the DIAGs, then the issue is most likely the regional and language settings in CONTROL Panel
Jul 13, 2009 | Dell Computers & Internet
I press a letter a number comes up as the letter
You have your number lock on. Turn it off and you should be fine.
Jan 28, 2009 | IBM 08K4800 Keyboard for Thinkpad 560Z,...
Mt3705 keyboard problem
You probably have the function scroll button on. See the blue numbers on the letters? press function scroll to take it off and see if that is your problem.
Jul 23, 2008 | Gateway MT3705 Notebook
Most likely, this is a hardware problem rather than a software one. While viruses and malware can cause oddities in keyboard and mice behavior, what both of you are describing appears to be due to the actual keys. On most laptops, except for more recent versions, the keyboard is one "unit". That is, if you were to pull off all of the keys on a keyboard, you would find that it is really just a series of buttons next to each other without physical separation between them. This means that it is quite possible to get solid or liquid debris (dust, dirt, food, etc.) into the cracks in between the keys. Over time this can accumulate to the point where nearby keys can get stuck together in such a way that when one key is pushed, the others also activate. To remedy this, I would purchase some cleaning fluid at any computer/electronics store (be sure to look for ones that are approved for use on laptop keyboards), a can of compressed air may also be useful, although it is possible that it would make the problem worse.
When the computer is turned off, apply the cleaning fluid and either make use of the compressed air or a vacuum cleaner near the problem keys. For maximum benefit, you can attempt to remove some of the keys to further get at any debris. After this, let the computer sit for a while (if you have used a liquid cleaning fluid) to be sure that it is completely dry. Restart the computer and see if the problem has resolved itself. Repeat if necessary.
Oct 18, 2007 | Dell Inspiron 2200 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
177 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
