Question about Neff U1661 Double circotherm super Electric Oven
Neff B1442 Oven -- Defective timer and clock
This oven is 2 years and 4 months old, so out of warranty! It has a digital timer controlled by knobs. Unfortunately I can no longer set the clock. When I try to set it, it simply reverts back to 0.00 immediately and continually flashes on off with a slightly faded tint. Almost as if it is shorting in some way -- I am not engineer so I could be completely wrong about this! Anyway any ideas as to how I can avoid a £60 callout for first 30 mins, and £45 per part hour thereafter plus parts would be much appreciated.
  • KAHANNAN Nov 25, 2008
    It is not flashing auto but if I depress and hold the button that I would normally press on to select the option I want, e.g. timer, clock, etc it shows "CO 3".
  • Neff Master
  • 3,463 Answers
Hi.
Is it flashing AUTO, If it is and you can'y reset it back to manual, then you have faulty timer.
Hope this helps
Posted on Nov 25, 2008
RECENTLY MOVED INTO A NEW HOUSE WITH A NEFF DOUBLE OVEN (OLD ONE). THE CLOCK IS FLASHING ALL THE TIME AND NOW THE MAIN OVEN WONT WORK - CAN YOU HELP PLS
Your oven might need to be reset first before it will work again normally.
The most common reset for NEFF double oven is to press and hold down the two arrow buttons while turning the small knob
Try it!
Oct 04, 2010 | Ovens
Smell has started in our 8 month old Neff oven. No obvious reason for it - pretty clean and no unusual food cooked. Any ideas ?
There may be a problem with the cooling or extraction fan on the oven. All Neff appliances come with a two year manufacturers warranty, so I would advise you call them out on 0844 892 8999. If you attempt a repair yourself, you could invalidate the warranty.
All the best.
Sep 01, 2010 | Neff U1461 Double circotherm plus Electric...
NEFF CIRCOFIRM OVEN HAS DIED? ITS 8 YEARS OLD, HAS ALWAYS WORKED WITHOUT FAULT BUT 2 DAYS AGO IT STOPED RESPONDING TO ANY CONTROL, AND THE WINDOW WHERE TEH TEMPERATURE RANGE IS DISPLAYED IS SHOWING -5- OR...
the chid lock is activated!! how did you manage to do that accidentally??? the instruction manual tells you how to disable it from memory it is turning the oven mode selector switch 3 times beetween the light position and off quickly.
Aug 27, 2010 | Neff B1641 Single circotherm super...
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Neff B1428
If it is a digital timer and u have display, thenyou must make sure it is set to manual and not flashing auto, or the oven will not work.
If it is an anologue timer tweak the knobs until you can see a hand symbol showing this is the manual mode.
If no display of any kind, and u are sure u have a supply to oven then timer could be faulty.
Hope this helps.
U must ensure that u have a supply to the oven befor trying to alter timer.
Plz rate solution.
Thanks.
Dec 31, 2008 | Neff B1428 Nostalgic Single circotherm...
Electric oven & grill not working no digital clock display
If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
They can be bypassed, but not recommended unless you know what you are doing..
If there is no display at all , then check to make sure you have supply to oven
Plz rate my solution.
Thanks.
Dec 16, 2008 | Neff U1661 Double circotherm super...
Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Nov 28, 2008 | Neff B1432 Single circotherm plus Electric...
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Neff U1661 Double circotherm super Electric Oven Logo
1,155 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
