Question about Whirlpool GGQ8831L Gas Dryer
Inglis Gas Dryer Does not heat up at all, No spark, no flame
Model #IE73001
Serial # MH3101758
Dryer is very clean with no blockage. I see no spark and no flame, any suggestions?
  • 1 more comment
  • mr rigid Feb 04, 2009
    HOW do i get at the gas valve and ignitor and where is the thermal fuse located? Inglis model # I e73001
  • tree_rat Mar 02, 2009
    dryer will not heat, it comes on and turns but no flame, replaced the igniter, and had fuses checked all good. now what? could the gas not be getting to the igniter
  • lvella_y Mar 09, 2009
    Dryer will not generate any heat. Where is the thermal fuse located?
  • 113 Answers
When you start the dryer , after a few seconds do you hear a distinct click sound from inside the bottom of the dryer at the burner assembly? If you do not, you most likely have a bad thermal fuse, part# 3392519 or 3390719, depending on your dryer. Its the same fuse just different shape, both will work. This is most likely your problem. If you do hear a click, you may have a bad ignitor. Best way to test is to check for 120 at the ignitor. If you have anymore questions or need parts feel free to ask in my forum at www.washermd.com, thanks, Dave
Posted on Dec 16, 2008
Why won't my inglis dryer heat up
if electric? check ur thermal shut off and thermistor with a multimeter. does it run at all? if it does it wont be thermal shut off but may be ur heating element? is it gas or electric? Gas? 1. may need to check ur coils which regulate the flow of gas, ? 2. CHECK Igniter which ignites the flame, or 3. CHECK THE glow bar. there are also thermostats on the heating eleemt you will want to check with a multimeter. the thermal cutoff, the hi-lo thermostat and the element itself.
Aug 16, 2014 | Whirlpool Inglis IP8200 Dryer
Dryer not drying
It could be the heating element but do not assume it is until you check it. If the element is fine the limits on the heater housing might be tripped and if that is the case the vent needs to be checked for blockage. Birdnest, snow, cobwebs, and such can cause limits to trip. On an electric model the fuse mounted on the blower kills the motor but on a gas model the fuse kills power to the gas valve. I have a full page of dryer repair info and service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 14, 2013 | Whirlpool Inglis IP8200 Dryer
Why is my inglis dryer not drying?
You must have a gas dryer. Assuming it is a gas dryer, the ignitor is working because she glows. the flame sensor is also working because the ignitor shuts down. The only other thing in the assembly is the solenoids which tend to work properly but short and die when warm, then when cool will work some more much later. very difficult to diagnose. Replace the solenoids and party on Amigo.
Jun 12, 2012 | Whirlpool Inglis IP8200 Dryer
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Gas flame will not turn on,
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 09, 2010 | GE DWXR485GBWW / DWXR485GBCC Gas Dryer
We have a commercial inglis gas dryer..under door is a model number JO-71200 when i search for it says no match.dryer quit about a week ago we replaced a few rollers then we noticed clothes weren't...
Well I'm not familiar with gas delivery systems on dryers, but I can tell you how they work on home heating boilers and I'm sure they are very similar. There are two type, standing pilot (which you have) and spark ignition. Spark ignition uses two electrodes with an electric spark to ignite the gas. Now your situation your dryer may have what is called a thermocouple which is like a little metal cylinder connected to a wire. When the flame is lit it heats that thermocouple which produces a voltage. That voltage keeps your gas valve open to keep the pilot light lit. If your pilot light is lit then the thermocouple is not bad. You need to check your circuit and see where the break is. Its true it could be a thermostat. To check a thermostat you need to take it off the dryer and you can either use a lighter or put it in boiling water till you hear is pop or open up. If you hear it pop twice then it is good (you'll hear it pop once when it heats up and once when it cools down). There is a circuit that keeps that gas valve open, and after 10 seconds something is opening that gas valve circuit, you need to see what all is connected to it, then you will solve your problem.
May 08, 2010 | Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Feb 04, 2009 | Dryers
It sounds like you have an intermittent gas valve. The ignitor is calling for heat however the gas valve doesnt want to open.
Make sure you turn off the gas and unplug before replacing.
Check for leaks after you reassemble.
Aug 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
1,804 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
