Question about RCA HD52W59 HDTV Projection Television
Hd52w59 convergence fuse
If the fuse dont fix it what else can i do
  • brady bowling
    brady bowling Nov 25, 2008
    the other day i jumped the fuse and after about 15 mins the tv started turning on and off
    Genius:
  • 1,030 Answers
What is wrong with you television ... does not have convergence. did you replace the fuse
Posted on Nov 25, 2008
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA hd52w59. I just got it today used and I don't have a remote for it. The colors wont converge and I think it is a Convergence Chip Failure from what I have read on here. But one of the ways...
chek to see is the setup menu has the word convergence on page.
if not the the problem is an open 0.4 fuse beside the flyback/center one of three in a row.
the fuse blows because the flyback need to be resolderd, cracks on pins.
Mar 24, 2011 | RCA HD52W59 HDTV Projection Television
Convergenc problems w/ RCA HD52W59 HDTV
sorry but u replace the incorec part , the board which control the convergence voltage on and off is the deflection board , now this board is about $100 - 150 , or if u want to fix it , just solder the flyback , just go to radio shack and get a 25watt solder station and solder rosin , also check for bad fuse , this fuse it dont look like the others , this is a 1/2 watt 250 pico fuse , and is next to the flyback , look like small brow squer little box , there is 3 and the one that is bad is the one in the middle , this 3 pico fuses are togethere u cant miss then , good look
Apr 16, 2010 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
convergence fuse is FL231 it will be middle one next to Flyback transfomer there is 3 of them small brown in color it will be the one in the middle 0.6 volts if bad it will cause lost of convergences
Nov 23, 2008 | RCA HD52W59 HDTV Projection Television
Convergence
in the tips and tricks section under ther fl231 article. This article explians why this fuse fails and how to fix it. it is my belief that is is bad solder connections.
Nov 17, 2008 | RCA HD52W59 HDTV Projection Television
FL231 RCA HD52W59
You dont want to leave that fuse jumped, as it blows when there is a problem with the convergence power supply, and if the power supplt surges again with that fuse jumped you will destroy the convergence power supply and the deflection board and the cost would be in excess of 500 for those two boards.
Aug 31, 2008 | RCA HD52W59 HDTV Projection Television
Convergence
is this the same convergence problem in your previous post.. no convergence on a hd52w59? no convergence option in setup?...fl231 a small fuse next to flyback being blown causes this. The reason this blowns is poor solder connections on the flyback
Mar 23, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD Projection TV Model HD52W59
you have a fusible link that has blown. This is what causes the convergence option no be erased from the menu. You will need to locate the blown link and replace it. They are identified by FLpreceeding the location number on the circuit board such FL221 and etc.
Mar 23, 2008 | RCA P61927 61" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
