PC cuts out within 10 seconds of switching on
I have made no changes to it but as soon as i switch on it dies. it has 2 g memory (max for board) and has been running fine.
    Problem Solver:
  • 6 Answers
Have u just upgraded the memory lately or anything if so take the memory out and try ur old ones againg i brought two memory but one was nackerd so i had to take it out that caused mine to turn off unexpectedly
Posted on Nov 25, 2008
Mother board appears to be getting to hot new ram modules installed recently running windows 7 with an ATA hard drive WD800 Number on mother board PB2390J9VSJXZI appears to have 3 ram modules...
Hi Please check the Processes From Task Manager window - Check how much is the Memory Usage - There will be Lot of Programs running - Check the one which is taking the Max and Right click on that Program and End Process - Remove the Program which is causing the Problem
- Better Run the Registry Cleaner tool and clean the Registry - Also check Run the PC Virus Check and remove the Viruses - Increase the Total Paging File Size by increasing the Virtual Memory .
http://www.registry-cleaner.net/ http://www.malwarebytes.org/
Best regards Tejodhar
Sep 18, 2011 | HP Computers & Internet
I have a p4m900mother board. i had 1gb ram in each slot. running 2gb ram. i replaced the one with a 2gb hoping to run 3gb ram but my pc will not boot. i have switched slots and still nothing. i can run up...
Make sure you have installed the correct type of ram into the board. Here are the ram specs for that board
• Memory:
Support DDR2 533/667 MHz
2 x DDR2 DIMM Memory Slot
Max. Supports up to 4GB Memory
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Biostar P4M900-M4 Motherboard
Sir how much graphic memory can spport my p5nmx-mx mthr board with 3gb ram inbuilt graghic memory means how much graphic memory it will show when i will use 3 gb memory {available graphic memory}
the max you will see if you are running vista is 1244. shared memory is calculated as followed.
(total memory-512)/2= dedicated shared video memory. (3000mb-512=2488/2=1244mb dedicated shared memory.
Nov 04, 2010 | ASUS Computers & Internet
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
Max memory supported by P5750-6001
I'm pretty sure without looking at the documentation for this motherboard that you can indeed install 2x512mb sticks on this board and it will work fine, Its just a question of whether your OS can access all of it.
Some old OS's cannot access more than 512 but anything above xp should be fine
May 23, 2009 | HP P5750-69001 - System Board/P4...
Asrock p4s61, tried 1gb pc3200 to max memory to 3gb, won't boot.
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
May 02, 2009 | Asrock P4S61 Motherboard
2 much memory?
First make sure your motherboard can handle the size memory stick you are attempting to install, find out the Max amount of RAM the board can handle per slot. If you are within the range then do a memory test after it is installed to see if the memory is good or has issues. Check out http://www.memtest86.com/ for a bootable memory test program.
Jul 10, 2008 | Computers & Internet
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
Computers & Internet Logo
371 people viewed this question
David Payne
David Payne
