Question about HP Color LaserJet 2600n Printer
Hp color laserjet printer gives 55.1 error
I know it is a DC controller error but i replace DC controller and power supply too but the error is same the problem not resolved.
    Sergeant:
  • 237 Answers
  1. Follow these steps to ensure proper reinstallment.
    Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.If the same error message occurs, reinstall the driver that came with your printer, or go to hewlett packards' website for the driver there.If you have done all of these steps and no help go to step number 3.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Posted on Nov 25, 2008
55.00.00 error message display on the control panel
Error 55 is a major Engine or DC controller issue.
HP LaserJet Enterprise Printers 55 00 0x and 55 0x 06 Errors
Try spares from salvaged printers. Look for "working pull from damaged unit". Of course reconfirm model and spare compatibility.
Printer Works RM1 9371 000 DC Controller As M775 mfp
HP LaserJet DC Controller For M775 Printer RM1 8898 - USD70+shipping
Mar 18, 2016 | HP LaserJet M775DN Laser Multifunction...
Hello I have a problem with the work printer. It is a 3500 hp color laser jet and it is having a 10.10.00 supply memory error. I'm not sure what to do. Can you please help me?
10.10.00 SUPPLY MEMORY ERROR
Missing memory on supply
Black print cartridge
1. Open and close the front door.
2. Ensure the cartridges are fully seated.
3. Swap the cartridge for the color indicated with a cartridge in another slot to determine whether the error follows the cartridge or stays with the slot. If the error follows the cartridge, replace that cartridge, otherwise, continue with step 4.
4. Check the memory controller PCB contacts to the memory tag. Clean if dirty.
5. Reseat the memory controller PCB connector J201 and DC controller PCB connector J1025.
6. Defective memory controller PCB, replace the memory controller PCB.
7. Defective DC controller PCB, replace the DC controller PCB
Aug 25, 2011 | HP Color LaserJet 3500 Printer
I want to know what the problem 59.CO message on my printer Laserjet colour 5550 and how to get it solved
59.XY PRINTER ERROR
A printer motor error has occurred.
(C)= developing disengaging motor rotation error / (0)= no color/black
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Jul 13, 2011 | HP LaserJet 5550 Printer
My hp color Laserjet cp3525dn displayed error 55.50. Resend upgrade.
I couldn't find an error code of 55.50 in the service manual.
All 55.xx errors are DC Controller problems.
I did find the message "resend upgrade".
That refers to a Firmware upgrade that didn't complete successfully.
If that's what happened in your case...restart the upgrade and keep away from the printer
until the upgrade finishes.
Jun 28, 2011 | HP CP3525DN Color LaserJet Printer
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
My 2600 laser printer have 55.1 error message its not working.
DC Controller error.
Turn printer off for 60 seconds. If it's plugged into a surge protector, plug the printer into a wall outlet. Power it on. If it works - good. If not check the firmware version and upgrade it if needed. Other wise replace the DC Controller.
Jan 11, 2010 | HP Color LaserJet 2600n Printer
10.92.00 cartridges not engaged error on Color Laserjet 3500. Replaced black cartridge. What should be my next step
check the contacts on the transfer unit, or replace the transfer unit. could also be the dc controller or the high voltage power supply pcb.
Aug 11, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
Error 58.04
This is from the service manual and should help you determine if you need to call in for service. If is in warranty I would anyways since the fuser would be covered if at fault.
58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
1. Reinstall the fuser. Check the connector
(J1901) between the fuser and product.
Replace the cable or fixing unit if the
connector is damaged.
2. Reconnect the connectors of the fuser
control PCA (J303, J305) and the DC
controller PCA (J107).
3. Replace the fuser. See Fuser
on page 191.
May 03, 2009 | HP LaserJet 5200tn Printer
Error 55
Error 55 (internal communication problem)
  • On the HP 2 series you have to replace both the dc controller and formatter boards. On all other printers it can be several things: DC controller, formatter, main motor
Jan 18, 2009 | HP LaserJet IIIp Printer
HP Color LaserJet 2600n Printer Logo
426 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
