Question about Nokia 6270 Cellular Phone
Call,call end and select below buttons are not working
Call,call end and select down buttons on the top panel are not working
This is problem of phone connector patta so change your phone patta and sovle problem.
Posted on Dec 04, 2008
Lg direct drive start button is not work" what's problem in machine
Take off the control panel. There is a little plastic arm behind the start button that may be worn down on the end and may not be making contact with the electronic button underneath.
To access the control panel on the WD14700RD:
  1. Disconnect the unit from power and water
  2. Remove the top: take off two screws at the back, push it backwards one inch and lift it off
  3. Take out the soap tray and remove two screws on the soap tray compartment.
  4. Remove the control panel: push down on the two arms on top of it so that it can pop out, and pull it out at the top and then lift it off the bottom hooks. Pull it out a little from the machine, about an inch.
  5. Remove the front plate from the control panel: there are 7 screws behind it. Rotate the control panel up or down in order to access the screws behind
  6. Now that the front plate of the control panel is loose, identify the arm of the button that has stopped working. Wrap a small amount (2-3 times around) of electrical or plumbers tape on the very end of the plastic arm. Or if there is a nib instead of an arm, a small dab of epoxy resin allowed to harden does the trick.
  7. Refit the control panel and test the button now works.
  8. Reassemble the control panel, top, and turn on water and power.
  9. Test once again.
And that's it! All you need is a screwdriver and some tape. Too easy. Hope the information helps out.
Sep 17, 2016 | LG Washing Machines
How can I change to setchannel search auto or man on a westinghouse tv mod ltv20v2sl?thankyou
Since the LTV20V2SL only has an NTSC (analog tuner), you may need a set top box to receive any stations. If you have analog cable or are close to a low-power station that still broadcasts an analog signal, you need to follow the steps below.
First, make sure that the input is set to TV. On the remote, there is a TV button in the second row of buttons below the arrow keys. It's on the left below the MTS button. You could also use the TV/Video button on the top of the TV. It's the right-most button and each press of the button will move through the entire list of available inputs. You can use the original remote to select your signal type with the TV/CATV (Over-the-air or different types of cable TV) button. It's on the right hand side of the row with the TV button. Next press CH. Scan on the remote. It's the second button from the right above the arrow keys.
Alternatively, you can use the on-screen menu. Press the Menu button on the remote (on the left above the arrow keys) or TV (the left-most button). Then use the left/right arrows to navigate to the TV sub-menu. Use the up/down arrows to select the appropriate line. First, set the second line to the correct Input signal with the left/right arrows and press Enter to confirm your choice. Then go down a line and press the right arrow key to start the Auto Scan. Note the Channel up/down arrows are up/down and the Volume up/down are left/right if you use the TV buttons.
I hope this helps.
(If you are using a set-top box, you will need to do the channel scan for that device.)
Feb 19, 2016 | Westinghouse Televison & Video
How to get to menu then adjust it to antena?
First make sure that an antenna is connected the coaxial input on the TV and the input is set to TV. There is an Input button on the top of the TV and on the original remote. On the remote, the Input button is below and slightly to the right of the 0 button. On the top of the TV, the Input button is the one closest to the Power button. You can toggle through the Inputs by pressing the Input button several times or use the up/down arrows and then press the Input button to select the input. (TV should be the top item in the list.)
Next press the Menu button on the remote, above and to the right of the arrow keys. (There is no Menu button on the TV.) Use the left/right arrows to navigate to Setup. Next use the up/down arrows to select CH setup. Press Enter. If you've set a PIN, you'll need to enter it. Use the up/down arrows to select the line Air/Cable, if you need to change the source of your signal. Press Enter. Use the left/right arrows to select your source. Press Enter to save the setting. Press Menu to exit. Return to this CH setup menu and use the up/down arrows to select CH Search and press Enter. If you are using an OTA antenna, use the left/right arrows to select Start and press Enter. Wait for the search to be completed. For cable sources, you'd need to select from Analog Search Start or Digital and Analog Search Start. Press Cancel and then Enter to exit the search.
Crutchfield has the manual for the LC-32D62U available from the product page under the Details tab: http://www.crutchfield.com/S-mhRC3OB2Fi4/p_284LC32D62/Sharp-LC-32D62U.html . The direct link to the manual is http://d2stobyut4u5rx.cloudfront.net/ImageBank/v20080124174400/Manuals/284/284LC32D62.PDF . The Input button use is available on page 30 of the manual. The channel search steps are shown on page 23.
I hope this helps. Please note, if you have an replacement universal remote, you may need to try multiple codes for Sharp TVs to get the Menu button to work. If your replacement remote doesn't have a Menu button or none of the codes work, then you'll need a different remote.
Nov 07, 2015 | Sharp Aquos Lc32d62u 32-inch 1080p Lcd...
How can i set it to load paper from the top
Go to Control Panel, then to your Printer. Right Click on it, then click on Printer Properties. Down at the bottom of the page, click on Preferences. Now select the type of paper ( on the top right-hand side), and then , below that, select Auto sheet Feeder. Job done.
Apr 24, 2014 | Canon PIXMA iP4200 InkJet Photo Printer
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Need a code for 37bv700b for sky remote number not on sky list
Hello
Toshiba has a lot of codes to check with Sky remote. They are:
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
536
581
216
253
063
746
726
508
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
OK.
Jul 21, 2011 | Televison & Video
SAYS GOT PAPER JAM
With the message should say where is the paper jam. If you can not find this information you can try:
  1. Pull the paper tray, specified on the Display Screen, completely out of the printer.
  2. Remove any jammed paper from inside the tray slots. Make sure there are no pieces of paper jammed in the tray slots.
  3. Make sure to use paper within specifications and that the paper is loaded correctly in the tray. See the Related Items below for additional information.
    NOTE: When the paper edge guides are correctly adjusted, there may be a small space between the paper and the guides.
  4. Adjust the length and width tray guides:
    1. Length guides: Press the sides of the guide, and then slide the guide until the arrow on the guide point to the appropriate paper size labeled on the bottom of the tray. When properly positioned, the guide will click into place.
    2. Width guides: Slide the width guides until the arrows on the guides point to the appropriate paper size labeled on the bottom of the tray. When properly positioned, the guides click into place.
  5. Remove the top sheet of paper from the tray.
  6. Re-install the paper tray in the printer, and make sure it is completely closed.
  7. Make sure the pick truck and ****** roller set is installed and seated properly. Clean or replace both of these roller mechanisms, if necessary. See the Related Items below.
If none of this clean the JAM message you might want to power OFF/ON the device.
If that also does not clear the message you can go a bit deeper and reset the device. THIS WILL CLEAR ALL YOUR SETTINGS, might inclusive clean TCP/IP settings. So I advise you to print configuration report first then.
If you wish to do this here are the steps. NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAM to their factory default values. The print count and the Adobe firmware serial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM. See the Related Items below for additional information.
  1. Press and hold the [Up] arrow button on the Control Panel, and then press the [OK] button. This will automatically display the Service Tools menu on the Display Screen.
  2. Press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
NOTE: The Configuration Page can be printed to help solve printing problems and obtain the best results from the printer. Access this page from the printer's Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Configuration Page], and then press the [OK] button to print.
  3. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main Menu.
Aug 27, 2010 | Xerox Phaser 8560DN Laser Printer
Automatic scroll does not work on touchpad unless you hold down the left click button
This can be set to scroll for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Virtual Scrolling"
Check the box beside Vertical Scrollong and then click OK on this window and the mouse window.
Close the control panel and you're on your way.
I hope this helps Fixya,
Chris
May 19, 2009 | Compaq Presario CQ60-220US PC Laptop
A white line on entire page
If you have the machine for three years then I would say the the print head is coming to the end of its life, there are two solutions,
1. Follow the instructions below and activate the jet substitution mode.
2. Get someone to remove the print head and clear the blocked jet manually.
Note: The print heads on these machines are very expensive so if you have to replace it, just buy a new machine as it will be cheaper then replacing this part!
Jet Substitution Mode bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Turn Jet Substitution Mode Off], and then press the [OK] button.
    NOTE: If the 'Turn Jet Substitution Mode Off' option is not displayed, the Jet Substitution mode is not enabled.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the main menu.
Mar 30, 2009 | Xerox Phaser 8500/DN Printer
Replace drum
1.Power off the printer.
2.Open the top cover.
3.Press and hold the gray oval button on the operator panel below the indicator lights
4.While continuing to hold down the button, power on the printer.
5.The lights on the front panel will flash twice, then release the button.
The drum counter should now be reset. End of procedure.
Nov 05, 2007 | OKI B4250 Led Printer
Nokia 6270 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
