It's the Premium 4-Port USB Hub. I have no problems using it. But, with, for example, the mouse plugged in, when my laptop starts (XP Pro SP2), the mouse won't be detected, and the light on the hub is not on, I have to re-plug it in everytime. Is it the hub or my laptop? Thanks.
  • 61 Answers
Go to device manager and rightclick on the usb root hum and turn off the power management option for all the usb root hub and try
Posted on Nov 25, 2008
Dell dv051
On a desktop you can actually buy a usb 2.0 pci card that goes inside the computer in one of the pci slots. 2.0 is the way to go because otherwise you'll be getting a message about how your device can run faster if it was plugged into a usb 2.0 port.
Mar 23, 2012 | Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
In windows xp sp2 my os did not recocnize my mouse. Previously it was working fine. But from 19/5/2010 it not recognize and when windows start it stuck in the middle of the screen. i tried with three...
Bro it is a normal problem of some hardware component units, depend on its hardware manufacturer. because some of the system units need to plug first all the peripherals before you start-up using the computer unit so that it will analyse and familiarize all the peripherals attach on it during reboot mode.Bro follow this steps. 1.plug your PS/2 or USB mouse connector to its port at the back of your system unit.
2. turn off or restart your system unit. 3. or turn on the system unit if you're using turn off mode. 4. wait while the hardware is on reboot mode till windows logo appears.
May 20, 2010 | Computers & Internet
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
I reinstalled my OS win XP . now no usb
Open Run and launch regedit
Browse to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\USBSTOR
In the right pane, look for an entry named Start. If you find one delete it. Your USB devices should start working immediately.
If not please report back.
Nov 11, 2009 | Acer TravelMate 240 Notebook
I am getting error power surge on hub port in windows xp pro
your usb hub is exceeding the power limit or you are attaching a device that is extracting more more , use a USB 2.0 port HUB with a power adapter if you are attaching more devices on hub
Sep 24, 2009 | Computers & Internet
One day the Belkin 7 port hub works the next day it doesn't
Your problems with the Belkin 7 port are not due to the Dell computer or the XP OS. To problem solve, select on USB port and stay with it, not the 2 top ports for your keyboard and mouse. 1. Plug in the power adapter, wiggle it about, widen the prongs, change outlets at the 120 v. end. 2. Use an simple hand magnifier and peer closely at the DC input plug and be positive that the center post and the minue side piece of metal if in firm constact with the plug. If cannot insure a firm fit, sligtly bend that tiny metal piece towards center. Option 2, use another adaptor with the precise voltage as the original and the idential pin that inserts into the module. 3. Use another or new USB connector.
This list does not imply a specific order of diagnosis. Your fundamental problem is the failure to delive DC power to the Belkin hub or to capture the hub to USB port signal. In a phrase, you gotta short somewhere.not an issue with the computer or the XP operating system. Bill Miller
Aug 25, 2009 | Belkin (F5U237) 7-Port USB Hub
Presario A900 A976TU USB Port Issues
It may be that you need to update your drivers
Start here
Microsoft's built in drivers may not be making best use of your hardware and causing the problem you describe.
The driver may be for the motherboard and not usb.
Either way it provided you with the opportunity to update other drivers too
Aug 24, 2009 | Compaq Computers & Internet
Usb power surge
The Safely Remove Hardware icon list all removeable devices regardless whether it is a USB or PCMCIA or a removeable CD/DVD drive etc.
To get around the problem with your USB device that exceeds the power limit of the computer's USB port. Get a powered USB hub and connect it to the computer's USB port and plug the USB device into the powered USB hub.
Apr 06, 2009 | IBM ThinkPad T30 2366 Notebook
KVM converter
Buy a usb hub and an usb extension, so that you can have 4 or 6 free usb at the front of your computer, and you can switch devices using usb rather then the mouse converter . Using the converter on mouse and keybord make easier for the plugs to slip out, and usb is better. Note some usb modem and some other device do not support usb hubs, you have to plug them straight into the free computer plug , if you have any.
Apr 09, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
