Question about Jensen 143307 Remote Control
Lost tv code
I programmed the remote to my tv and it worked fine for a while, then it wouldn't work anymore, so I tested the batteries, reset the remote, and tried programming it again, it still will not work. It will work for the satellite.
  • 8 more comments
  • Anonymous Dec 27, 2007
    rca tv codes for cool sat remote
  • Anonymous Feb 19, 2008
    i have ajvc tv
  • Anonymous Feb 24, 2008
    J'ai une TV Sony et une télécommande Jensen avec le bon numéro de code. Cependant j'ai égaré les instructions pour être capable d'entrer les 4 chiffres de codes. Pouvez-vous m'aider s.v.p. Merci Yves
  • JoeRueda Jul 31, 2008
    I need the code for my TV, it's an old Orion...
    Thanks in advance.
  • fady_69 Nov 05, 2008
    I need to re-program my remote to the tv, the TV is JVC
  • Anonymous Nov 16, 2008
    i lost tv cde
  • Anonymous Nov 25, 2008
    my remote just randomly stopped working
  • alleymjames Dec 02, 2008
    I have a Jensen remote model #DC jer 323 remote I programed it for my 27" Sharp TV and one day it just stopped working.
  • Anonymous Feb 02, 2009
    Lost my code for my jensen remote.
  • Anonymous Feb 04, 2009
    j v c multi brand remote control unit lp20303-009
I lost the code for my JVC tv, Need to reprograme it.
Posted on Nov 05, 2008
I have a toshiba tv with this remote how do i activate it to the tv?
Posted on Oct 16, 2008
Need codes for sharp TV 27 inch Jensen 323 remote
Posted on Jan 30, 2008
  • 259 Answers
Here are some of the codeslost tv code - 2.gif still looking for manual
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Mitsubishi TV4.gif 0093, 0150, 0178, 0019
JVC2.gif VCR 0067, 0041, 0008
JVC DVD1.gif 0558, 0623
samlost tv code - 1.gifimg src="http://i.fixya.net/uploads/images/1.gif" alt="1.gif" class="h_mi" /> codes is 1004,1005,1006,1012,1013,1015,1017,1019
Motorola2.gif Cable2.gif Box: 5000, 5003, 5046, 5047, 5052
Comment by Gigatech, posted on Dec 10, 2007 Here is some helpful information4.gif I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device4.gif button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Posted on Dec 15, 2007
I had my remote working fine, then after changing the batteries i cant get it to connect again
Your remote has lost the code you programmed into it. This can happen if the batteries run down completely before you replace them or if you take too long to replace them. You need to program the code again to make it work.
If you don't know or have the correct code, please post back with your TV brand and I will obtain the correct code for you. If you need codes, please also confirm you are using the URC-3445 remote so I can provide the right codes.
Regards,
BElectric
Dec 04, 2010 | One For All URC-3445 Remote Control
I just programmed my dish #2 remote control to a tv. The remote is not working. I cannot access the guide menu "etc". What do I need to do? This is a second tv and the remote worked just fine before....
It sounds like the remote would need to be programmed to the receiver itself. It may have lost it's programming when the TV code was put in.
To program remote to Satellite:
1. Access System Information screen.
2. Note the # on the bottom where it was Secondary Remote Address.
3. Hold SAT until all buttons on top of the remote light up.
4. Let go and while it's blinking enter a number between 1-15 and press #
5. Press record 3 times and test remote.
Tommy Faust
DISH Network
Sep 25, 2010 | DISH Network IR Remote Control
Remote stopped working so I cant use the tv what can I do I was trying to set the firect tv remote and could not get it to work. After I tried that the remote to the tv would not work anymore. I tried...
your best bet is going to be contacting rca and having them send you out a new remote alot of the universals have a 50/50 chance of having the needed frequency so I try to say away from them
hope this helped
Robb
Apr 22, 2010 | RCA RCU600M Remote Control
It stopped working, but battery is fine. the tv lost power and ever since then, the remote has not worked. i think it needs to be reset, but i don't have the code. it is a sony v203 remote.
If you haven't had the batteries out of the remote for more than a few moments, maybe the remote still has its code intact. If the TV lost power because of a power dip, maybe the TV is a bit scrambled. Try unplugging the TV for about 15 minutes, then plug back in. It should go through channel search, etc. If you respond again, include the exact model number of your TV please.
Aug 28, 2009 | Sony (RT-V203) Remote Control
27" sylvania tv stuck on one channel
unplug tv for about half a hour and replug it back in to reset it and see if that works..I also have that big remote and it worked find for me the first time so maybe tv just needs to be reset. hope that helps
Apr 05, 2009 | Televison & Video
Remote tv compatible codes
the default for the rh7823w remote is to operate lg tvs. Popping out the batteries should reset the default. my manual saysto select a different tv hold down the tv power button, press the number buttons for the manufacturer code then release power button.
codes are
LG/Goldstar 1(default), 2
zenith 1,3,4
samsung 6,7
sony 8,9
hitachi 4
good luck
Apr 04, 2009 | Televison & Video
Need to know "HOW TO" set up RCR312W
You have to hold the component button (TV) and enter the code from http://www.rca.com/codefinder. The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
Feb 15, 2009 | RCA Universal Remote Control
Philips universal remote control cl034
hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
Mar 08, 2008 | Philips Magnavox Learning Universal Remote
Remote control
My suggestion is to post the manufacturers name & model number of your remote, or search for the manufacturers support website > look for your model of remote > view/down load the instructions and code list for your universal remote. With the manual and manufacturers code list you shouldn't have a problem re programming it.
If it's not a universal? Then remove the batteries for a minute or two, then replace them and that should reset your OEM remote to the default settings, which hopefully will get it to work for you again.
Good luck
Feb 14, 2008 | Televison & Video
Jensen 143307 Remote Control Logo
1,179 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
