HDMI Problem: Picture shifted to the left about 1 inch
Hi yes I have had this TV for about 2 years now and have never connected anything to the HDMI port. I now have purchased a Playstation 3 and HDMI cable. When using the HDMI cable the picture is shifted to the left. Also connected a DVD player with an HDMI cable same problem. Connected both units to another TV using the HDMI cable and picture is fine.
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
Posted on Jan 04, 2008
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
SOURCE: Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
Posted on Jul 11, 2008
Can I connect 2 HDMI
Hi, yes you can connect two hdmi they should come up as hdmi 1 and hdmi 2 on your tv hand controller.
Dec 27, 2015 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
You must match the TV's input connections and the Roku output on your remote. This means if the Roku's output is connected to your TV's "HDMI 2" (or A/V 2, etc.), you must be able to select HDMI 2 (or A/V 2, etc) on the TV - either with your remote or pressing a button on the TV itself.
Sometimes, the TV will skip over unused inputs when it was first set up. This is done to reduce the number of button presses to go from say "HDMI 1" to "HDMI 4" by programming OUT the HDMI 2 & HDMI 3 choices.
You'll need to program IN the input that your TV uses to connect the Roku if it isn't already available. You MUST connect cables properly if not using HDMI. RGB is Red-Green-Blue and must be connected to RGB jacks at the Roku and TV for a picture and the the White & Red (left and right) audio must connect the the corresponding Red / White audio jacks - or it will provide strange results.
Make sure the power plug is connected to an outlet that is ON and connected to the power jack on the Roku box itself. Unless you have a defective Roku box or TV, it SHOULD work. You can try using a different HDMI or A/V jacks on the TV to determine if it is the TV jacks or not.
Sep 10, 2013 | Televison & Video
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
Mar 21, 2011 | LG Televison & Video
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
Feb 02, 2011 | Sanyo 42 in. LCD TV
Tv out of alignment
the picture shifted 2 inches to the right
Jun 28, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Mitsu 57731 problems have wide bar across screen
This is an ongoing problem with Mitsubishi DLP HDTV's contact the Customer Service at 1-800-332-211. Tell them this has been going on for a while and you want the TV either Fixed or Replaced. Ask for Adrianne Hardt, she is a Customer Service Manager...... TELL HER RICK GRIFFITH told you to call.
I am in the 4th week negociations with Mitsubishi over these exact problems. I purchased my 57" DLP HDTV in Aug of 06. Replaced the Lamp 3 times and have had 5 Service calls. I DO NOT have and extended Warranty. Mitsubishi provided me with the extention in writing and stated if any problem occurred again they would replace the Unit or provided monetary compensation.
Good Luck and be persistant.
Any of you can email me for from info and
Feb 23, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Dec 21, 2008 | Polaroid Computers & Internet
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
Shifted Picture
Yes. This problem comes about by actually pressing the center ring accidentally during normal viewing. Just press and hold the left or right side of the ring until the pciture straightens itself out again (if the black portion of the screen is to the right of the picture, press the right ring; if it is to the left side, press the left ring).
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 51PW9363 51" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
