Question about Plumbing
Grohe Atrio Bath Shower Mixer Flow Problem
Flow to bath OK
Flow to shower head slow insuffient to operate pump
Could it be to do with the aquadimmer?
If not ,any other suggestios
    Scholar:
  • 50 Answers
Check for a flow restrictor in the showerhead, also a clogged intake screen or filter in the showerhead. or hose or pipe...
Posted on Jan 05, 2009
Grotherm 800 bath shower mixer just fitted with pumped feed but not giving any pressure
Hello Mark Bentley,
In California... (MY OPINION... every bit)
It is called "social engineering".
FOR More than 25 years... before "the drought)
and without public knowledge MY state mandated
water flow restriction at the VALVES
Although the shower VALVES... were MAUFACTURED
prepared for 1/2 inch PIPE FITTINGS... FINAL
MACHINING severely reduced the holes through
the side of a typical body... were smaller than the
EASILY altered WATER RESRICTERS IN EVERY
shower-head & faucet NOW sold in CALIFORNIA...
Back then... That was 1½ or 2½ GPM
water restriction... (I don't remember which).
It was part of the VALVES CONTRUCTION...
I am PRETTY SURE you are going to have to call
GROHE and find out if there is ANYTHING they
can recommend... now that your VALVES
are installed & finished over... What can increase the
allowed water FLOW...
Only a traveling DENTIST would have the tool
to work from the INSIDE of the valve...
Just my opinion...
Carnac the Magnificent
Jun 13, 2017 | Home
I have a bath shower mixer with a shower set. I cannot get water to come out of the bath tap, only for the shower head. The fitting in the middle if the taps will not stay down.
Go right away back for replace if there is warranty in between 8 days, if not then there should often a simple mixer maintenance set for sale for the brand and exact model mix faucet. often from simple plastic if its an older (mostly solid) mixfaucet then only to put it 24 hours in a bucket of vinegar or descaling agent.
Mar 01, 2017 | Home
I've just installed a grohe mixer shower/bath
Did you account for wall thickness?
Dec 17, 2012 | Water Heaters
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Shower water pressure is dismal at best, girls cannot get soap out of hair, is there a way to adjust amount of water coming out of shower head, we have a delta monitor single valve assembly.
Yes, try changing the shower head and do not get one of those water saver heads...and even if you get a regular one take out the flow restrictor before installing it if it has one....it will be just inside the thread part and wil be a plastic or rubber piece with a small hole in it to slow down the water flow...
heatman101
Sep 08, 2010 | Delta & Single Handle Shower Faucet
I I have a 3 way bath/shower/overhead shower mixer valve to fit and am not sure where the pipes should go, there is a hot and cold feed in, but only 2 feeds out, I need feeds for 1. bath filler, 2....
When installing a flexishower head, install it in front of the actual shower head with a diverter switch. If you try to operate two shower heads at once, you may suffer poor water pressure. There are handheld shower sets sold which are installed to existing shower assemblies with ease. Rememer to use plumber's tape and protect your stainless steel by wrapping you pliers teeth in electrical tape.
Jan 15, 2010 | Delta 3 Function Showerhead & Grail...
Plumbing Logo
669 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
