Question about Acer Computers & Internet
The keyboard keys are not operating as labelled. eg to get @ on the page I have to type " on the keyboard. How do I correct this please?
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    are u pressing the fn key while trying to use the labelled key?
    President:
  • Acer Master
  • 1,314 Answers
Drlalitv, I really doubt a desktop keyboard has a fn key.
adrian, this is caused by the incorrect keyboard language setting. Just go into the control panel, click on regional and language options, then select the proper english language that corresponds to your keyboard....for instance if the @ is above the 2 on your keyboard, select the united states option.
Thanks and please take a moment to rate as fixya.
Posted on Nov 25, 2008
Keyboard types umlaut instead of quote
probably a "accessibilty" setting or a keyboard flaw. try to turn of all accessibility options and swap you keyboard with a standard usb one. hope it help
Dec 12, 2014 | HP Computers & Internet
I was press "z" but
Check the input input. For some languages??, the meaning of key changes (eg Romanian - Y and Z keys to switch between them). Choose English as the language of the keyboard and all will be solved.
If I could be of further assistance, let meknow. If this helps or solves the issue, please rate it and give a testimonialfor my response.
Jul 17, 2011 | Compaq Keyboard
Please help. The 789uiopjkl;m./ keys have keypad numerals on the front bevel. when I try to type "uio" for example I get "456" and "jkl" gives me "123". To get the...
The number lock feature is enabled. You should see an indicator for the Num Lock (lit when on) that is next to the Caps Lock indicator.
You should be able to disable the lock by pressing Fn and Num Lock together on the keyboard. (On some Sony Vaio keyboards, type CTRL+ALT+NumLock or Shift+NumLock.) The number lock should be at the top of the keyboard near the F1-F12 keys. Sometimes the key is shared with the Scroll Lock function (otherwise it will be nearby). It's really easy for the Number lock to be enabled on some Sony keyboards; just some dirt between the keys can enable it when you didn't turn it on intentionally.
I hope this helps.
(I don't have the VGP-WKB1 wireless Sony keyboard and can't find a good picture of it to find the Num Lock key for this model.)
Jul 08, 2011 | Sony VAIO VGP-WKB1 Keyboard
Hi, my acer aspire 4930's keyboard not functioning correctly.. when i press letter "a" it appear as "A1" same as "Q" appears "Q1".. pls help me
Hi.
Try cleaning the keyboard with a clean, dry paintbrush just in case there is anything stuck under the keys. Once you have cleaned the keyboard try typing keys to see if it does the same thing. If the keys type as normal then you have resolved the problem.
If the keys still type other characters along with the letter then there is a strong possibility that the keyboard needs to be replaced.
This usually happens when something has been spilt on the keyboard causing it to type random characters or the characters directly above or below them.
Seeing as the keyboard is a laptop keyboard you can use a wireles/wired keyboard or you can use the on-screen keyboard if you can't get the keyboard to work.
If there is anything else please post back.
Good luck.
Jun 07, 2011 | Computers & Internet
My @ symbol is stuck on the " sign. I do not have an ALT GRA key. I have an ALT CAR key and and ALT key but neither seems to help. I've tried hitting the Fn key and 2 at the same time but still no...
Sounds like your keyboard in in UK mode, but is labeled for US. Or the other way.
In a UK keyboard, Shift+' (the key which is two spaces to the right of "L") should give you an @ sign.
Depending on your Operating System, you can use the CONTROL PANEL and REGIONAL SETTINGS to set the keyboard to be a USA keyboard, and then Shift+2 will give you an @ sign.
http://en.wikipedia.org/wiki/Keyboard_layout is a good reference for keyboard layouts.
Apr 17, 2011 | Toshiba 310CDT Keyboard
Am using Win XP When I turn the pc on with recovery disk inserted the Press Any Key to boot from cd" screen comes up but pressing any key does not get a response then it continues on to the sign in...
OK! Lets troubleshoot this together.
First thing we want to do is verify that your keyboard & mouse and plugged into the correct places and are powered up and able to work.
Turn your computer on and look at your keyboard and tell me if any lights are on to show that it has power and is operational.
Watch the keyboard lights until the computer gets to the login page and tell me if the lights come on and stay on? Or do the lights turn on for a moment and then turn off again?
If you do not see any lights, please clarify if there are NO LIGHTS on your style of keyboard or if there are lights but they are not lighting up.
If your keyboard has lights and they are not lighting up at all, then turn off the computer and unplug the mouse and keyboard and swap them around. Then turn the computer on again and tell me if the lights come on and the mouse and keyboard become operational.
Once we verify this we can continue to the next step of troubleshooting. Please report what you find and I will help you solve this.
Nov 08, 2010 | IBM NetVista PC Desktop
MANUAL FOR KEYBORD 5188
Type 5C Keyboard to USB Adapter
Operation Manual
Type 5C Keyboard to USB Adapter 5188
TYPE 5C KEYBOARD TO USB ADAPTER Page 1
This equipment generates, uses, and can radiate radio frequency energy and if not installed and used in accordance
with the instruction manual, may cause interference to radio communications. It has been tested and found to
comply with the limits for a Class A computing device in accordance with the specifications in Subpart J of Part 15
of FCC rules, which are designed to provide reasonable protection against such interference when the equipment is
operated in a commercial environment. Operation of this equipment in a residential area is likely to cause
interference, in which case the user at his own expense will be required to take whatever measures may be required
to correct the interference.
Contents
Chapter Page
1. Specifications 2
2. Introduction 3
3. Installation 3
4. Technical notes 3
5. Part Numbers and Accessories 4
1. Specifications Compatible with:
Sunä Type 5C keyboard and mouse (includes Sun Type 6 keyboard)
Ultra Spec Server Control Switch, P/N 5185 or 5195
Sun Sunblade 100 workstation
USB compliant PC workstations (a USB compliant operating system which supports the USB HID 1.1
device class specification is required)
Power:
USB bus powered device. Current load is 100 mA max (adapter only). If also powering Type 5C keyboard
and mouse requires an additional 400mA max.
Size:
4.0” x 2.4” x 1.0”
Shipping Weight:
1 lbs.
Warranty:
Ultra Spec Cables, Inc. warrants all hardware and components of the Type 5C Keyboard to USB Adapter,
with proper installation and normal use, for one year from the date of purchase.
During the warranty period, Ultra Spec Cables, Inc. will, at its option, either repair or replace hardware and
components that prove to be defective.
If your product should fail during the warranty period, phone our technical support department at 1-800-
622-2537 for warranty service (return to factory) instructions.
TYPE 5C KEYBOARD TO USB ADAPTER Page 2
2. Introduction
The Type 5C Keyboard to USB Adapter (P/N 5188) allows a USB compatible workstation to be connected to the
Server Control Switch (P/N 5185 or 5195). The adapter converts keyboard scan codes from the type 5C keyboard to
equivalent USB keyboard scan codes. The adapter also converts the mouse data to USB compatible mouse data.
The Type 5C Keyboard to USB Adapter can also be used in a standalone setup, where it is connected between a
Type 5C Keyboard/mouse and a USB based workstation.
3. Installation
3.1 Between Type 5C keyboard and workstation (standalone operation)
For all installations it is recommended that the equipment be powered off for system interconnection and/or changes
to a setup.
• Connect the port labeled To Type 5C Keyboard to either minidin8 connector on the Type 5C keyboard using a
straight through minidin8 cable (P/N 8002 or equivalent). If using a mouse, connect it to the other minidin8
connector on the keyboard.
• Connect the port labeled To Computer USB Port to any workstation USB port using a USB Type A to Type B
cable (P/N 4021 or equivalent). This type of cable is used for connecting a HUB or other device upstream to
another HUB or a host controller.
3.2 Between Server Control Switch and workstation (system operation)
to a setup.
• Connect the port labeled To Type 5C Keyboard to any Server Control switch CPU port using a straight through
• Connect the video output of the workstation to the Server Control Switch video input connector using an
appropriate cable/converter for connector and sync conversion
• Connect and power on the rest of the Server Control Switch system per the appropriate installation instructions.
4. Technical notes
Keyboard
The Type 5C Keyboard to USB Adapter emulates a Sun Type 6 USB keyboard (P/N 3201273-01) and a Sun
Crossbow USB mouse (P/N 3703632-01). The Type 5C and Type 6 keyboards match in available keys, however
several keys are relocated on the Type 6 keyboard. The adapter appropriately maps the key codes generated to the
key legends on the keyboard (i.e. all keys work the way they are labeled).
TYPE 5C KEYBOARD TO USB ADAPTER Page 3
Important Note Regarding Standby Operation:
USB supports a SUSPEND/RESUME capability that has various and incompatible implementations across differing
hardware platforms. This can affect the operation of the adapter if the workstation supports a low power or standby
mode with an incompatible implementation. Low power or standby mode is normally activated through a menu
selection (using the mouse) or by pressing the POWER key on the keyboard (upper rightmost key on both the Type
5C and Type 6 USB keyboards). For this reason, the POWER key on the Type 5C keyboard IS DISABLED when
using the adapter. In addition, it is important not to activate low power or standby mode through other means.
WHEN IN LOW POWER OR STANDBY MODE THE SYSTEM MAY NOT WAKE UP THROUGH
KEYBOARD OR MOUSE ACTIVITY, REQUIRING A HARD POWER-DOWN TO RECOVER.
In addition, the POWER key on the Type 5C keyboard does not have the capability to power-on a system as it
would when connected to a Type 5C compatible workstation (nor does a Type 6 USB keyboard have this capability
when connected to a USB workstation).
5. Part numbers and Accessories
5188 Type 5C Keyboard to USB Adapter
4021 Cable, USB Type A/B, M/M 0.5M
4022 Cable, USB Type A/B, M/M 1M
4023 Cable, USB Type A/B, M/M 2M
4024 Cable, USB Type A/B, M/M 3M
4025 Cable, USB Type A/B, M/M 4.6M
Jul 10, 2009 | HP Multimedia Cordless Keyboard/Mouse...
Keyboard Keys Mismatch error
this could be caused by a couple of different issues:
1st Depending on the operating system you have loaded, it could have the wrong keyboard type or emulation selected.
2nd The keyboard or its cable could be bad, it will not necessarily quit until it goes completely out.
Mar 05, 2009 | HP Compaq Presario V5000Z Notebook
The keyboard on my gateway m-6337 is all messed up. eg: when i hit the key "H" i get "hj" it came with vista and i loaded xp, then put back vista. problem started after...
Try going to Control Panel> Regional and language options>Keyboard and Languages and change the language layout to your preference.
Oct 31, 2008 | Computers & Internet
I was cleaning the keyboard of the computer. When I had finished the keys were not typing correctly. It appears that the letters and keys do not correspond. Eg. When I type P an A comes up on screen. ...
That means a broken keyboard, if you used liquid try drying keyboard with cold hair using an hairdryer. If it is a desktop buy a replacement keyboard, as it is quite an inexpensive part.
Jul 06, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
