Question about Dewalt DW999K 7/8" Cordless SDS Rotary Hammer
Greasing - when & where?
I have no manual for my dw999k (if anyone can upload one that would be great!)
I can't work out where to apply grease to this drill. My previous drill had a chamber to fill up but not this one. Amy ideas much appreciated.
Cheers
  • 23 Answers
Www.dewaltservicenet.com
this drill has self-lubricating bearings and shouldn't need grease
Posted on Nov 26, 2008
  • booba loo Jan 04, 2014
    My B&D started leaking grease from the gear case, so I would say that there is definitely grease in the unit.
How do you oil the singer xl.1000
You should never oil a computerized (electronic) sewing machine. You do need to clean the lint from it at intervals. Singer has the instruction manual available on their support site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/8332a66e46ddc22f7bc62f0139bf8fbd03c55b23.pdf . See page 113 (114 of the PDF) for the cleaning information.
I hope this helps.
(I have used mechanical sewing machines which need regular oiling and greasing. The computerized systems are pre-lubricated at the factory and that lubrication should last the machine's lifetime.)
Mar 02, 2015 | Singer Sewing Machines
Greasing the drive shaft
yes grease the drive shafts. there is no greasing point, you have to remove the attachment and remove the inner shafts. Heres the manual, hope it helps
http://www.mediafire.com/view/a33fr2038d5u1cr
Feb 10, 2014 | Stihl HT101 Pole pruner
DeWalt dwd520 grease
Found it from links at the DeWalt Web Site.
Jan 04, 2014 | Dewalt DW999K 7/8" Cordless SDS Rotary...
Greasing the arm vertically and horizontally
Remove the cover then apply grease to the moving area of the saw
Aug 25, 2012 | Craftsman Sears Radial Arm Saw Arm 815688...
What causes ztr front wheel to squeek in motion?
i would take them off and clean off the old grease and apply fresh grease on all moving parts including the the wheel caster section
Jul 14, 2012 | Toro Zero Turn Rider 74366 Lawn Mower...
There is oil dripping down into the bown from the mixer.
Oil dripping from the mixer indicates that the grease in thegearbox has turned to oil. In that case it needs servicing. It needs to be sentin for re-greasing. Gear breakingcould be another cause, but if your machine working correctly then you cansolve this problem by simply re-greasing it. Hope this will help you. Good Luck.
Aug 06, 2011 | KitchenAid Food Mixers
How do you do any maintenance (oiling or greasing - whichever is applicable) of rear wheel bearings in a 1987 jaguar xj6?
You don't. The bearing is greased for life. If the bearing is noisy it needs replacement.
FYI: Dismantling and greasing bearings does more harm than good due to the introduction of dirt, no matter how careful you are.
Modern greases are very sophisticated formulas of oil and soaps and last a long time.
Long gone are the days of white soap chassis grease that lasted 15,000 miles.
If the manufacture wanted it greased they would have installed a grease nipple in the housing.
However, over greasing a wheel bearing can sling grease onto nearby brakes and hoses.
The drive shaft CV joints are another thing however and you will find grease nipples in each joint behind the splash sleeves.
Jan 14, 2011 | 1987 Jaguar XJ6
Is there a specific type of grease gun ad grease I
There is really no special grease gun to get. Any type of grease gun will work. I personally use a high temp. grease at the shop I work at. When greasing anything never over grease a joint , it causes a mess and will cause premature failure. All that is needed is three pumps of the grease gun.
Aug 16, 2009 | 1993 Lincoln Town Car
"Greasing" battery posts and clamps
Yes you are correct. I have never heard that term before. There is a battery protector spray you can buy and apply on top of a good clean pattery post.
You know If I lived in the back woods I guess greasing the post would be another option.
Got to give credit for ingenuity
Jul 18, 2009 | 2001 Ford Focus
Noisy rear suspension
is there a grease fitting on the swing arm? take out the bolts that hold the shock in place one at a time and grease them. use a bit of WD40 at all the pivot points until you find the source of the squeek.
May 24, 2009 | 2000 MZ Baghira
Dewalt DW999K 7/8" Cordless SDS Rotary Hammer Logo
296 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
