Question about Samsung Digimax i6 PMP Digital Camera
Samsung digimx i6 pmp camera installation
Have tried to install the software on my pc which is a Dell dimension 9100 intel pentium 4 processor but the hardrive does not seem to read the cd. Any other cds work!! So please please help me?
    President:
  • 2,961 Answers
Go to this link and download the manual and driver, hope your sorted! http://www.samsungcamerausa.com/productdetails.asp?command=&navtab=down
Posted on Jan 03, 2007
  • andrew pester
    andrew pester Jan 03, 2007
    Sorry meant to say click on drivers and manuals on left side, then select catagory; 'life style series' then your i6 camera.
What kind of processor does a dell dimension 1100 have?
Dell 1100
Single core 478 Celeron D 2.80 GHZ
The best I can tell it has a an Intel 865GV chipset based motherboard, according to intel's website (http://compare.intel.com/PCC/showchart.aspx?mmID=135,138&familyID=10&culture=en-US) you can install a Pentium D (dual core :) ) processor.
Dec 19, 2012 | Dell Dimension 2400 PC Desktop
Dimensions
Dell Support > Dimension 8300 Desktop PC > Main Support Page,
http://support.dell.com/support/edocs/systems/dim8300/sm/index.htm
Left-click on - Technical Specifications - in the list.
Left-click on - Physical - in the list.
Height: How tall the computer tower is. Outside edge to outside edge measurement.
Width: How wide the computer tower is. Outside edge to outside edge measurement.
Depth: How long the computer tower is. Outside edge to outside edge measurement.
If you meant Specifications instead;
A) Processor:
Intel Celeron, or Pentium 4, that uses a Socket 478 processor socket.
Either a 533MegaHertz Front Side Bus, or an 800MHz FSB.
(Dell also indicates the Intel Pentium 4 Extreme Edition processors are supported. Too expensive for what you get in return)
http://en.wikipedia.org/wiki/Socket_478
B) Ram Memory:
DDR Sdram that operates at 333MHz, or 400MegaHertz.
PC2700 and PC3200 respectively.
Maximum TOTAL Amount is 4GigaByte
There are 4 Ram Memory slots. EACH slot has a Maximum Amount of 1GB.
C) Motherboard Chipset:
Northbridge chip: Intel 875P. (Part Number Intel 82875P )
(For Intel the Northbridge chip is the MCH, for this particular Northbridge chipset.
Memory Controller Hub)
The Southbridge chip is an Intel 82801EB (Part Number) or Intel 82801ER (P/N)
Commonly known as the Intel ICH5, or Intel ICH5R.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
In the chart go down on the right side to - 875P
Looking across, and at the headings, you can see under the heading - Processors, that there are more Intel processors supported, than just the Intel Celeron's, and Pentium 4's.
Core2 Duo, Core2 Quad, Core2 Extreme, Pentium Dual Core, and Xeon.
Problem is they don't use a Socket 478 processor socket.
All except for the Xeon ( 'Zee-On' ) use an LGA 775 processor socket.
Xeon models use a Socket 603, or Socket 604, or LGA 771, processor socket.
It is just processors that the Intel 875P chipset will support.
D) Graphics Expansion Slot:
AGP
Uses AGP 8X graphics cards.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 03, 2011 | Dell Dimension 8300 PC Desktop
When i start up my dimension 3100 dell desktop instead of a green light i get a flashing amber light. people say it is the power supply but the light wouldnt even come on if it was. can you please help me?
No, the light WOULD come on if it was a Power Supply problem.
1) If ALL of the LED lights on your computer were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses from 51 to 125 Watts. Depends on what Processor it is.
Dell Dimension 3100 desktop computer?
An Intel Pentium 4.
Intel Pentium 4 model 640.
Can operate up to a frequency rate of 3.2GigaHertz. (3.2GHz)
Fits in a Socket 775 processor socket. (Also know as Socket T)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
Can use up to 84 Watts.
You have enough power to light that LED light, but not enough power to turn the Processor on.
Dell Support > Dell Dimension 3100 > Service Manual > Advanced Troubleshooting > System Lights,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124612
"Power Light - Blinking yellow - A power supply or system board {Motherboard} failure has occurred"
Dell Dimension 3100 desktop computer Service Manual, (Free from Dell Support),
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts > Power Supply
Regards,
joecoolvette
Jul 20, 2011 | Dell Dimension 3100 PC Desktop
I have a dimension 2400. the current processor is a pentium 4 2.2 can i swap the processor with a intel core duo ??
After checking the specs of this here : http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
i can confirm that a intel core duo would not be supported without changing the motherboard, and probably the memory too.
Rytech Computer Services Limited
Oct 12, 2010 | Dell Dimension 2400 PC Desktop
I bought a pentium 4 3.0 ghz 800 mhz & my
The motherboard chipset of the Dell Dimension 2300 Desktop PC, will not support a processor with an 800MHz Front Side Bus frequency rate.
Only Intel Pentium 4's that use a Socket 478, 1.75 Volts, and a maximum of a 400MHz FSB.
The Intel Pentium 4 HT 3.0GHz processor has an 800MHz FSB, (As you have already stated), and uses 1.475 to 1.55 Volts.
The motherboard chipset for that Dell Dimension 2300, is an Intel 845GL.
This list on Wikipedia, shows you parameters the Intel 845GL chipset supports,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Not a good outcome, sorry. Just stating the facts.
Jan 08, 2010 | Dell Dimension 2300 PC Desktop
Compatibility continued
You can get a very detailed analysis of your machines guts, installed software and installed updates and MS fixes, with the Belarc Advisor. It's a free utility but uses Internet Explorer for display purposes.
Belarc Advisor
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
DELL OptiPlex GX150 Upgrading
The fastest processor you can install in a GX150 is a Pentium III 1.13 Ghz processor.
The Socket 370 was a design used only for P3 processors.
Max RAM for that system is 512MB no way to upgrade past that.
If you paid $100 for a GX150, you paid way too much (You can buy a refurbished Dell Dimension C521 for $225 at their refurb site)
Jan 26, 2009 | Dell OptiPlex GX150 PC Desktop
Dell Dimension 9100 - Motherboard & Compatible CPUs
Intel Pentium 4 Socket-T (LGA775) with Hyper-Threading or Dual-Core support, cache 1MB or 2Mb for 9100, or just 2Mb cache for 9150. I know of some of these machines having pentium D installed but I do not believe a Core 2 Duo is an option, whereas Dual-Core is. Good Luck!
Nov 11, 2008 | Dell Inspiron 9100 Motherboard - N4878...
Getting my CPU to support the SSE2 Instruction Set
Hi The SSE2 Instruction set was introduced by Intel in its Pentium 4 range of CPU's. Unfortunatly your pc has a Pentium 3 cpu. The motherboard in your pc does not support the pentium 4 processor. Your only option Im affraid is a new pc
Aug 25, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Open Questions:
Samsung Digimax i6 PMP Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
