Question about LG WM1814CW Front Load Washer
Lg front loader
My washing machine stop at 9 minutes and do not want to spin at all. It is not overloaded and we did check the filter, the pipes is clean, the door is properly close but it still is not spinning. The machine is 2 years old
Please can somebody help me?
Thanks Sandra
    Sergeant:
    Champion:
  • 291 Answers
Check the pump to make sure its clear ,,,,, the front of the pump if i remember right turns to open
Posted on Nov 25, 2008
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Front loader will not spin
oe code is pump blocked, but because you have cleaned it, make sure the pipe from pump is not blocked
Feb 04, 2012 | LG Washing Machines
I am having an issue with my LG front loader washing machine model number WM1815cs. The water will not drain and the clothes will not spin out. Everything works fine until the rinse/spin cycle and it just...
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG WM1815CS Front Load Washer
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
Front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Sep 11, 2008 | Washing Machines
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
LG WM1814CW Front Load Washer Logo
113 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
